First post, by Akuma
Gods (c) 1991 The Bitmap Brothers (published by Renegade Software)
When choosing one of the combinations that tries to load PADLIB.BIN the program crashes as that file is not present.
I found another version in Gods PC Review Cover Disc from 1991 albeit under another filename CADLIB.BIN
After copying PBEEPER.BIN/PTANDY.BIN to PADLIB.BIN the game starts (with other problems) confirming that the file is required. Replacing it with CADLIB.BIN just causes another crash although I think that it should be packed.
I narrowed it down to any combination of the following:
Display: Tandy 16 colour
Sound : Adlib/Roland LAPC-1/Sound Blaster
dosbox error messages:
15106392: FILES:file open command 0 file padlib.bin
495495916: CPU:CPU:GRP5:Illegal Call 7
495495916: CPU:Illegal/Unhandled opcode FF7F
495495917: CPU:Illegal Unhandled Interrupt Called 6
