First post, by Oetker
I've been gathering info on upgrading Pentium 3 CPUs (mostly from this forum) and have attempted to summarize it in number of tables.
Questions:
1. Have I omitted CPU designs, for example, I read somewhere there's an FC-PGA Mendocino Celerons 550.
2. How important is BIOS support for Coppermine / Tualatin. From what I can gather, boards don't really need to support these chips, they need to not be actively blocking them. Otherwise, support just means the correct name/specs are shown.
3. Does the 1133MHz Coppermine actually exist in the wild
4. Do Slot 1 -> FC-PGA (not PGA2) adapters with a VRM exist?
5. What is the significance of a voltage clamp chip on a slocket. Is this for Coppermine-T chips?
6. Is it true that a Tualatin-compatible socket (or slocket) will no longer support PPGA chips?
    50.73 KiB
    30.57 KiB
    31.84 KiB
Reply 1 of 3, by DenizOezmen
Oetker wrote on 2020-06-24, 17:19:
If I recall correctly, there might be differences in L2 cache initialization between Pentium III cores. I haven't encountered a problem personally, but there might be edge cases. (Would need to do research on this one, though.) "Support" also usually includes the question of whether or not the applicable microcode updates are included in the BIOS image.
The Slot 1 variant in cC0 stepping was recalled, but S370 variants in cD0 stepping do exist.
That might depend on the way the modification is done. I've been using cD0 stepping Coppermine-Ts on a Lin-Lin adapter and a Upgradeware Slot-T without issues. I haven't checked whether this also works for non-"T" Coppermines.
Edit: One additional thought that is sometimes overlooked: Generally, the newer the core stepping, the more its power current draw increases. So, even if a certain processor "runs" on a given mainboard, the on-board VRM might be running out of spec, depending on what CPUs the mainboard designer laid it out for.
Reply 2 of 3, by Oetker
DenizOezmen wrote on 2020-06-24, 17:45:
Thanks for your reply! With that statement, I meant that PPGA Celerons would no longer work. I.e. with an upgraded socket, you're always backwards compatible one step; FC-PGA can also do PPGA, FC-PGA2 can also do FC-PGA.
Reply 3 of 3, by DenizOezmen
Oetker wrote on 2020-06-24, 17:50:
Ah, right, sorry, I did overlook that detail. In that case, no idea. 😀
