Tandy Nano - 3 Voice Soundcard ISA - Lowprofile
First post, by matze79
A Building Kit Version of the Tandy Card, featuring only necessary Stuff:
212.36 KiB
134.22 KiB
properly one of the smallest Soundcard existing.
I needed a extra low profile Version for a Friend.
Why not make one ?
and here it is!
Only 3.8cm in height with Connector.
Its almost similar to the First Version but with added Fixes.
Reply 2 of 133, by ElBrunzy
omg! a true Sega Master System's SN76489 into your computer! I would like to have one since the saa1099 emulation from CM/S is not perfect and we found bug using sbvgm.exe from OplX playing back .vgm into CM/S. I'll try to bring this into Oplx's attention and if he think it would be compatible with sbvgm I would be interested into getting a kit. Maybe I would get two kit and build one for our friend OplX as a gift.
Reply 3 of 133, by matze79
188.8 KiB
  List of Parts
_______________
[b]< building time >[/b]
\ ^__^
\ (oo)\_______
(__)\ )\/\
||----w |
C1,C2,C3,C10,12 - 100nf 104 Ceramic Capacitor
C4,C5 - 10uf Electrolyt Capacitor
C6 - 68pf Ceramic Capacitor
C7 - 47nf 473 Ceramic Capacitor
C8 - 220uf Electrolyt Capacitor
C9 - 470uf " "
C11 - 470nf 474 Ceramic Capacitor
D1,D2 - Diodes 1N4001 - watch Polarity
IC1 - 74LS74 IC
IC2 - 74HC688 Comparator IC
IC3 - LM386 Amplifer IC
IC5 - ATTINY13 Reset/Muting Circuit MCU
J1 - 3,5mm Headphone Jack
JP2/SPK - 2 Pin Header (Internal Speaker Connection)
JP1 - 3 Pin Header (Jumper Settings)
R1 - 10 Ohm Resistor
R2 - 33 Ohm Resistor
R3 - Variable Trimpot 10k (Volume Setting)
R4,R9 - 1k Resistor
R13 - 2,2k Resistor
R_FIX - 10kOhm Resistor
T1 - NPN Transistor
U$1 - Socket DIP 16
U$1 - SN76489 Soundchip
Errata:
misordered 470uf Capacitor, Size to big, but fits.
PCB Errata - R3 Trimpot Holes bit too small
Bus Noise, fix add 10k Ohm Resistor.
R2 and C12 are switched, R2 should be in C12 and C12 in R2 Position.
126.89 KiB
Assembled Card with components in right Position 😉
202.59 KiB
Reply 5 of 133, by root42
ElBrunzy wrote on 2020-07-03, 20:25:
What do you mean about bus noise exactly ?
Some whistling and noisy sounds when the PC is doing stuff. Very common on sound cards that get their power for amplification from the ISA bus. Not sure if matze uses a voltage regulator to generate some less noisy voltage. Lots of cards have this issue more or less.
EDIT: saw the voltage regulator! So the noise creeps in somewhere else.
YouTube and Bonus
Reply 6 of 133, by matze79
There is no Voltage Regulator.
A 10k Resistor on VR will eliminate most of the noise.
You can listen to the Video.
I will try later to record some VGMs.
Any wishes ?
The Amp is powered over 2 Diodes from 12V.
In the SMD Version everything is powered from 7805 it was not enough to just Power the Soundchip.
Also found another Error the Filter was wrong, C12 and R3 are switched in Place.
https://www.youtube.com/watch?v=PVJx0jjLjX0
Reply 7 of 133, by matze79
Another Video:
https://www.youtube.com/watch?v=EGr8Vi2HBHU
Titles:
Paku Paku
Police Quest II
SBVGM playing some Sega SMS Game Themes:
Alex the Kidd - Main theme
Batman Returns - Main theme
Reply 8 of 133, by tomexplodes
Is there any place to get one of these already assembled? I have hand tremors thanks to MS and can't really do soldering.
1.) MS-DOS 6.22, Pentium 233mhz, 32mb RAM, S3 Trio64, Sound Blaster Pro 2
2.) Windows 98SE with Unofficial SP3, AMD Athlon 1.3ghz, 768mb RAM, Geforce 4 MX 440 64mb AGP, Sound Blaster Live! Value
Reply 9 of 133, by ElBrunzy
matze79 wrote on 2020-07-04, 07:34:
Any wishes ?
One of my favorite soundtrack is on the SEGA Master System was Miracle Warrior's ending music. I was doing some testing of oplx's sbvgm.exe and it's one of the benchmark music. It can be quite problematic so I would be very interested to know how it sound on your creation. Since it's one of those YM2413/SN76489 theme sound and the problem is that it declare both chip in the vgm, I'll put both version, use the one that ever work.
    mwarrior.zip
    3.69 KiB
    86 downloads
Reply 10 of 133, by ElBrunzy
matze79 wrote on 2020-07-04, 13:05:
haha wow it's amazing ! You'r product seem to work allright already !
I hope you did not forgot I wanted one
Reply 11 of 133, by ElBrunzy
tomexplodes wrote on 2020-07-04, 15:45:
I see you are in New York, it's quite near where I live, I would be glad to assemble one for you and the ship it your way. I'm already discussing with matz79.
OK... last time I do three message to do three reply ... damn, that project have me so enthusiast!
Reply 12 of 133, by tomexplodes
ElBrunzy wrote on 2020-07-04, 21:01:
Thank you for the offer! I have sent you a PM.
Reply 13 of 133, by matze79
i can`t send to USA due to Corona. (USA is very SPECIAL ..)
Sending from Germany costs currently 36,99€ to USA, only Priority Mail avaible.
No small letters possible..
i have only few DHT kits left. if anyone is interested.
Reply 14 of 133, by dr.zeissler
I think beside an euro-pc, such a soundcard could be interesting for my A2286 too.
Currently I am using a SC-1630 Formosa with primary ide with cf-card as hard-disk.
Reply 15 of 133, by root42
matze79 wrote on 2020-07-06, 08:18:
Wow, I didn't notice this until now, but indeed: DHL doesn't offer those shipment options for USA anymore. That's insane!
YouTube and Bonus
Reply 16 of 133, by matze79
Yeah the insane thing about is you can Ship without issues from Czech. But i can`t drive there just to send 2-3 Parcels.
Reply 17 of 133, by ElBrunzy
root42: I dont really care about the isa noise sound in that case. My impression is that it wont be a problem if using to play vgm with sbvgm.exe under msdos. Also maybe some sierra games, but I expect it to occur sparingly when you switch screen or stuff like that.
matze79: I was here to say that I wanted to use a socket so I could experiment with SN76489 and SN76489AN, but I'm glad to see you already took care of that. I see you ship the AN version from the picture but you list the non-AN version. I guess your target was Tandy so you went with the AN? For now the only thing I know is that the phase is inverted so it's probably meaningless difference in between those two chip version.
Also, matze79, thanks for the assembly information, I will take care about that.
Reply 19 of 133, by matze79
ElBrunzy wrote on 2020-07-11, 05:19:
matze79 a question that just crossed my mind: when did you experimented bus noise ?
Only on "high volume levels."
E.g. on hdd access.
I don`t hear any difference between the two.
Just used what i was be able to purchase 😀
