First post, by stopi
Hello! Where can I find AT power plug in Europe? I need the connector only for making AT power supply from standard ATX unit. I wasn't able to find it in my country Poland. I can see only full ATX->AT adapters but it's little expensive here.
Reply 1 of 26, by PC Hoarder Patrol
Try searching online for the Molex crimp housing part number (link below) - you may find ir or an equivalent locally or thru eBay (far east?)
https://www.molex.com/molex/products/part-det … ings/0903311003
Reply 4 of 26, by ahyeadude
I recommend buying a converter that also supplies the -5V that ATX does not supply. I believe it was used by certain ISA cards. Also, one with a dummy load on the 3.3V rail since AT doesn't use it. Leaving it floating could cause stability issues in the ATX power supply.
ATX to AT adapters, which one do I need and why?
Reply 6 of 26, by SETBLASTER
i bought the -5v version on ebay like 3 years ago
I wish i bought more, but only got 1, i cant find those anymore
the difference is just a couple cables that are connected to a white plastic square and another round component, that in terms of electronics i have no idea of what its name is.
Reply 7 of 26, by SETBLASTER
this is the one i bought
in case you want to modify one of the non -5v available even on china sites like aliexpress.
but i dont know what are these 2 components, maybe someone on vogons has a clear idea of what they are :
1) white rectangle; (searched the words on google and found nothing)
2)black circle covered with rubber (wich connects to the white wire that makes -5v), i dont want to take the rubber out to look whats inside because i could need to cut it.
Reply 9 of 26, by ykot
Curiously, up until now I have been using ATX power supplies (mostly mid-end to high-end versions) wired to AT connector without any load on 3.3V rail and no issues whatsoever.
But I am curious about the dummy load: on the photo I can see a 20 Ohm resistor rated for 10W, which at 3.3V would correspond to 165 mA of current and ~0.5W of power. The load seems to be very small and resistor seems to be rated for much higher wattage, so what is the deal? Would a 20 Ohm / 2W resistor be sufficient for that purpose?
Reply 10 of 26, by cyclone3d
The white thing is the dummy load. It is a ceramic resistor.
The other thing is a shrink tube wrapped circuit that provides the -5v for power supplies that don't supply -5v by themselves. It is actually a pretty simple circuit.
See here for more info:
https://forum.allaboutcircuits.com/threads/pc … mputers.128266/
It is a shame that the eBay seller antronst is no longer selling them as there is a definite market for them. Maybe they weren't making enough money or were not able to source some of the needed parts anymore.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 13 of 26, by Horun
Get any ATX to AT adapter. Then get a 7905C (cv, cp, etc BUT not a 79L05) or UA7905C. also need two small caps, a ~2.2uF and a 1uF. Input goes to the -12v line, output to the AT connector pin.
Mouser carries, L7905CV for $0.79, or L7905CP for $1.41 or UA7905CKCS for $0.96. Total with caps about $3 max plus shipping. You do not need a heatsink on it from my experience. Use some rubber tape to cover.
Make sure your ATX can deliver 0.5A or better on the -12v, some cheap ones only have max of 0.3A....
datasheet link: https://www.mouser.com/datasheet/2/389/l79-1849327.pdf
source: https://www.mouser.com/c/power/power-manageme … larity=Negative
    12.17 KiB
Reply 14 of 26, by gdjacobs
Inverting regulators are also very common and work nicely, although you need to take a bit more care in filtering.
Reply 15 of 26, by Horun
Good thought, that way could use the +12v ! I was looking at a few premade ones a while ago, this was in my history: https://www.ebay.com/itm/174976929699 best to add the mentioned 470uF cap to help with ripple....
Reply 16 of 26, by GabrielKnight123
I bought one as well from the guy on eBay he said he used a good quality -5 volt converter instead of the low quality ones from elsewhere, I bought two from him a 20 pin and a 24 pin and they work great, I'm interested in making my own just like his with a -5 volt converter and a 5 or 10 watt resistor to sell to people once I have made them, I have all the soldering gear and crimping tools I would just have to source where to get the same converter or one in the same size and quality, I removed the heat shrink on one of my converters to find more info on it but I didn't find any on google can someone please have a look at the pictures below, my google searching is not that great. Also it draws from the +12 volt and not the -12 volt
    1.17 MiB
    1.02 MiB
Reply 17 of 26, by Horun
Interesting. Can you show a full picture of the adapter cabling ? The datasheet for ACT4070YH is same as the ACT4070B series and is not a Negative output (of course the data can be wrong). And every source is China.
Best you look for an equal part that can be found on Mouser or Digikey.... just my observation
Reply 18 of 26, by GabrielKnight123
Horun wrote on 2023-04-16, 03:41:
Sure will but in about an hour I'm using it to scan memory on a 286 atm with 3 passes
Reply 19 of 26, by GabrielKnight123
Here's the 20 pin adapter pictures I put a piece of paper between the cables to see them clearly
    1.45 MiB
    1.15 MiB
    1.84 MiB
