Nuked Opl3
First post, by Mark_81
Hi Guys
At the moment i'm using DosBox Opl Emulation but I heard Nuked Opl3 is more accurate
i have downloaded a patch but I don't know how to install
My dosbox version is 074.3
Reply 2 of 7, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
you need to compile Dosbox source with the patch applied to the source. Oruse the DOSBox-EXE build that has the patch already applied, if I'm not mistaken.
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 4 of 7, by Dominus
DOSBox Moderator
No 😉
Look at Dosbox wiki on how to conpile Dosbox, do that and then try your hands at applying the patch
Reply 5 of 7, by JessicaJones
If you don't want to compile dosbox and just want to hear the difference between various OPL emulators, do this:
- capture music using dosbox to DRO file (CTRL ALT F7)
- install https://audacious-media-player.org/
- go to settings, find the adplug and there you can choose between 4 OPL emulators, including nuked OPL3.
- play your DRO file using audacious after seleting an emulator
=> I don't hear any difference between dosbox (woodyopl) and nuked OPL3.
If you choose MAME OPL, you can hear a lot of difference.
Also included is ken silverman's emulator
(see screenshot)
You can save your DRO file to WAV using the filewriter plugin of audacious (so it's saved to WAV by using the selected OPL emulator)
    10.45 KiB
MS-DOS music addict - DOSBox/AdPlug enthusiast
Reply 6 of 7, by Mark_81
Jessica
you were right, there are no significant differences except for MAME OPL
I've recorded from Dosbox with CTRL+F7
i got DRO File
Audaciosu play correctly DRO files
I Want to convert DRO in .WAV..
How i have to do with Audacious?
thanks
Reply 7 of 7, by JessicaJones
In audacious: settings -> sound -> FileWriter plugin (choose WAV)
Now play the DRO file you want to convert to WAV using audacious.
You won't hear any audio, all output is written to the WAV file
