First post, by dreamblaster
[UPDATE 04.03.2023]
New thread for X16 launch here : DreamBlaster X16 + X16GS Release
Final X16GS looks like this :
The attachment X16GS_FRONT.jpg is no longer available
[UPDATED 25.10.2020]
DreamBlaster X16 - prototyping/development board
Full featured board intended for testing and soundbank/software development.
I am now making a derived board X8, which is less excessive in features than X16.
Also making X16L : lighter version of X16
initial full X16 prototype :
The attachment X16.png is no longer available
The attachment X16_prototype.JPG is no longer available
Light X16L prototype :
Same basic specs, but more relevant form factor, similar to X8
1 GByte Flash
8 MByte SDRAM
16 Core DSP (SAM5716B)
The attachment X16L.png is no longer available
The attachment X8_x16_CommonPCB.png is no longer available
Thanks for your support !
Reply 1 of 52, by jaZz_KCS
Wow, 1GB flash for sounds for old DOS games.... Time to whip out the old Dream 5000 SDK and start constructing some fine sounding banks, I guess? 😁
Good work.
Reply 2 of 52, by Trelokk
Which DAC chip are you using? I'd be interested if this is capable of driving speakers like my Creative Stage Air 2.1 soundbar and at least 250 Ohm headphones (like my Beyerdymanics DT990 Edition). To make it perfect, a switch for toggling between Line Out and Headphone Out would be nice, similar to devices like the M-Audio Super DAC.
In general, I would be quite keen on being able to get my hands on a modern soundcard once more which has the capability of adding a wavetable module. Creative removed that aeons ago. It could even breathe new life into my DB50XG card which I still have in a DOXBox setup here (provided it would be compatible with this). I hope a proper case is also planned for this. 😉
1GB flash is probably really a bit excessive. Often bigger soundbanks are not necessarily better than small ones. In fact, the best modules out there like the SC55 or DB50XG managed to produce excellent MIDI music with just 4MB. But it also depends on what you want to do with it - I am talking about MIDI for classic games from the 90s such as Doom, Duke3D or Descent.
If this is really happening, someone will hopefully make a conversion of H. Bredel's 8MBGM Enhanced SF2 soundfont. I would immediately uninstall VirtualMIDISynth after that. But let's not get ahead of ourselves. ^^ Anyway, a very promising project!
Reply 3 of 52, by chrismeyer6
This sounds like a great project. Can't wait to see how it turns out.
Reply 4 of 52, by appiah4
Ok.. Not sure how I missed this, but so this basically looks like.. An external MIDI module / USB Audio Device hybrid with digital audio out and headphone amp? I can see that it also has Line In so I am guessing it can do audio processing internally? And there is bot a 64Mbit DRAM and a Micron chip that I think is actual NAND storage? What are you cooking up Serge.. Are you telling me I can actually upload ROM (*cough*MT-32*cough*) files onto this device and run software (*cough*MUNT*cough*) on it or something? Because if you are, take my money..
Ok, ok, this appears to have no processor and the Dream chip does all the interesting stuff. But maybe a similar audio centric SBC that can run MUNT and BASSMIDI, FluidSynth or something instead of using a Dream chip down the line 😉 A man can dream..
Very interested in this project, keep us posted 😀
Reply 5 of 52, by Trelokk
If this is going to be a full-fledged sound card with a proper DAC, headphone amp *AND* MIDI capabilities that can be used with a modern OS, this would be the most interesting project for me on this forum until now.
Reply 6 of 52, by dreamblaster
Trelokk wrote on 2020-07-07, 11:15:
yes that's the intention
Reply 7 of 52, by Trelokk
Outstanding. For me this now just needs to be able to handle 250 Ohm headphones and should ideally have a switch to toggle between Line Out and Headphone Out. Then you could ask pretty much any price actually, I'd still order a unit. With case, no questions asked.
Is it already decided which DAC and headphone amp chip will be used or it's still too early to tell?
Reply 8 of 52, by dreamblaster
Trelokk wrote on 2020-07-08, 08:39:
I will further develop X8 first , which has no headphone amp
Reply 9 of 52, by Trelokk
No problem. Curious to see how that one will turn out, too. I'll be waiting for this one, however. Time is not a relevant factor here.
Reply 10 of 52, by Nitroraptor53
Hey! I might be getting some money today. If I do, no guarantees, get the money, could I make a donation of around $250 USD?
Reply 11 of 52, by dreamblaster
Nitroraptor53 wrote on 2020-10-10, 16:52:
That is very kind, I am grateful for your support, but I am not accepting donations or pre-orders for X16.
Feel free to PM me, especially if you wish to support my projects, by buying other sound cards (that are completed already).
Reply 12 of 52, by Nitroraptor53
dreamblaster wrote on 2020-10-10, 20:03:
Oh ok. Also this is a cool project and I wish you best of luck!
Reply 13 of 52, by dreamblaster
Lighter redesign of X16, X16L, after feedback :
Reply 14 of 52, by appiah4
*Applause*
Reply 15 of 52, by dreamblaster
X16L board ready. - blue edition !
Still quite some firmware development ahead, before possible release.
Reply 16 of 52, by darry
Very nice !
Is there anything planned on the soundbank front for this (either custom made or from Dream) ?
Reply 18 of 52, by subnet_zero
Quite impressive. Is there a reason why you use a mini-usb connector, like you did with the x2? 🤔 ....I better stock up those cables.
Reply 19 of 52, by dreamblaster
subnet_zero wrote on 2021-02-02, 22:31:
mini usb through hole version, is very solid
as opposed to a micro usb which i ripped off in a prototype, during testing.
so yeah, because i like it, and you can give these old cables a new life 😀
