First post, by dreamblaster
Hi
I made a Atari/C64/Sega to PC gamepad/joystick converter.
The pcb has X and Y trim button.
Tested using Sega master system controller : all directions and buttons work fine.
Here's a quick demo : https://youtu.be/JTbkkPpRozo
This is a small solder kit, available here : https://www.serdashop.com/GAMEPADDB15
Thanks for your support !
