First post, by Marco
Colleagues,
Next issue. I suddenly won’t get my card (ensoniq soundscape s2000) to work on midi 2/9. Program ssinit always says Irq in use. When I select it anyway and test midi I get the message irq2 not responding.
Just three hrs ago it worked I just Switched slot. Yes I tried all slots but same behavior. 2/9 seem free according to MSD see screenshot.
Any idea?
Pc is 486dx/2 66 vlb with award bios
Thank you in advance
1) VLSI SCAMP 311 | 386SX25@TI486SXLC2-50@63 | 16MB | CL-GD5434 | CT2830| SCC-1 | MT32 | WDC160GB/7200/8MB | Fast-SCSI AHA 1542CF + BlueSCSI v2/15k U320
2) SIS486 | 486DX/2 66(@80) | 32MB | TGUI9440 | LAPC-I
Reply 1 of 15, by gdjacobs
IRQ 2/9 is used by ACPI. Can you disable it and go with APM or no power management at all?
Reply 2 of 15, by Horun
Marco wrote on 2020-07-01, 23:27:
Colleagues,
Hmm so you put it back in the slot that worked and now it does not ? Clean the edge connector with ISO alc on a paper towel and try again in same slot it did work. Make sure you run ssinit DOS boot not some WIn9x window. Just a thought: if it worked then why did you move it (the old: if not broke then why fix it theory) ?
Reply 3 of 15, by Marco
Thanks colleagues. I replaced for test purpose the card with an scc1 which is working fine at 2/9.
PM is already disabled but I check for maybe further options in the bios that I might have forgotten.
Also the point with cleaning connectors I will do.
Ssinit I did. Really annoyed at all a bit by that 486dx vlb Board with regards to io base and Irq addresses.
Running my sb16 now with scc1 works fine at the moment but yes: only for dune2 and doom. Strangely no music or fx for mk(2) and no fm at all. Also scc-1 Check reports wrong adress. I go mad although everything should be separated
Irq 2/9 + 330 mpu
Irg5/dma1+5/220= sb16 plus mpu at 300
Network at Irq 10 io 340 (Card reports error Double usage when setting to 320 though)?!!!
At the end I think I will have to install win95/98 to get kind of a “good“ overview of Ressource usage etc.
But hey that’s why I did the project no pain....
Reply 4 of 15, by jmarsh
Marco wrote on 2020-07-03, 06:07:
Irq 2/9 + 330 mpu
It's not just the base address that matters. NE2000 cards use 32 I/O ports so if you set the base to 320 it would occupy all addresses between 320->340 and conflict with the MPU401 at 330.
Reply 5 of 15, by Marco
True???? I will check that right after breakfast 😀
Ah okay: ....boards, occupy up to 32 registers—for example, from 0x320 to 0x33f.
I will change accordingly. So good to have at least “20” distance.
Reply 6 of 15, by Marco
Changed address. No chance. Although music via scc1 is playing something is not right. See screenshot. FM although not working yet 😤
Reply 7 of 15, by keropi
It could just be a case where the system chipset just won't allow IRQ2/9 to be free.
I have a couple 486 motherboards like that - one is VLB with VIA chipset the other PCI with SIS chipset.
It depends on how the board is wired in my experience, no change in bios or settings can fix that.
🎵 🎧 MK1869, PCMIDI MPU , OrpheusII , Action Rewind , Megacard and 🎶GoldLib soundcard website
Reply 8 of 15, by Marco
Is this really true? That would be worst case ever!
Anyway doom and dune2 and mortal kombat even larry3 plays midi. Cannot imagine that they are using by default others than 2/9 u know
It’s a chicony 471b rev2 MB
Reply 9 of 15, by Marco
Ok I seem to have lot of other issues. Cannot even install win95/98 even with all cards taken out. I have to dive deeper I think. Damn
Reply 10 of 15, by Marco
Seem to have a memory error
Reply 11 of 15, by Marco
Ok so windows 95 installed and it uses all above mentioned irq bases and dmas now without problem. Ok it’s 2am now 😅
I will just not care about that checkscc.exe damn tool!
So everything fine
Thanks a lot.
Reply 12 of 15, by jakethompson1
gdjacobs wrote on 2020-07-03, 00:42:
He's talking VLB so pretty confident to say there is no ACPI 😁
That said, I was just reading some of the posts here about the (optional) VGA vertical blank interrupt and don't know if that could be a factor.
Reply 13 of 15, by gdjacobs
jakethompson1 wrote on 2020-07-04, 04:55:
True dat. Didn't notice he's rocking a 486. 🙁
If it's just the PIC reserving the IRQ, you should be okay.
Reply 14 of 15, by Marco
Everything is working now. I was mislead by the checkscc.exe error message only
Reply 15 of 15, by Marco
Update final:
No mistake at the end. The IRQ 2/9 won’t work flawless on that chicony. Although scc-1 is running in practice but showing errors in checktools, my soundscape refuses still completely for midi.
Tested now on my 386er board: no problem. All tests passed!
Ain’t that strange?!
