First post, by appiah4
I have a lot of serial mice, some of which are NOS. The issue I have with them is that ball mice are a pain in the ass even when they are clean as a whistle. So I have been looking into getting my PS/2 optical mice to work on my older PCs. Unfortunately, none of them appear to be serial compatible, so a simple PS/2 to Serial adapter does not help.
I was wondering if ISA PS/2 controller cards are actually a thing that can be bought? I've done a google and ebay search on it and came up with little.
Barring that, what are the other options?
Reply 1 of 8, by aha2940
I see this: Another PS/2 Mouse ISA (ISA8) card adapter but I'm pretty sure I also saw someone making active PS/2-to-serial converters that work with any PS/2 mice, but can't find the thread now. Another option would be using those old serial optical mice that require a special mousepad to work, there are some NOS on certain auction web site.
Reply 2 of 8, by appiah4
Thanks I emailed the make of the first card, hopefully he still has/makes some..
Reply 4 of 8, by cyclone3d
maxtherabbit wrote on 2020-07-02, 14:27:
I didn't read all 18 pages of that thread but it sounds to me like it can end up being a decent sized project depending on your board.
How many people are going to want, much less be able to, modify their motherboard for PS/2 support in addition to possibly having to modify their BIOS?
Quick issues I saw:
1. Must have KBC with PS/2 support
2. Must wire up IRQ12
3. Can mess with Turbo settings... have to figure out which pin on the KBC is used for Turbo since not all boards use the same pin.
4. May have to mod BIOS
5. Have to run at least 1 bodge wire to an ISA slot for IRQ12... more if you don't have an adapter with everything else integrated into it.
6. Adapter height is iffy if the KBC is on the back of the board because it can cause interference with the expansion cards.
7. Your KBC may be soldered.
Seems like a huge hassle to me though it would be really nice if a universal / easily configurable adapter could be made. Gives me an idea but not sure how feasible it would be.
Edit: It seems like it would have also been appropriate to link the thread to the ISA PS/2 mouse adapter card - this is what you want:
viewtopic.php?f=46&t=67488
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 5 of 8, by maxtherabbit
1) you can swap KBCs
2) ok so what?
3) if you have a physical turbo switch this is a non issue it's only to allow for toggle via keystroke
4) nope, rio444 posted a TSR for that
5) I designed a PCB for it look toward the end of the thread
6) PCB clears that
7) so desolder it like a champion
Reply 6 of 8, by appiah4
The PCB doesn't help me in most cases because KBCs are almost always inconveniently located between the ISA connectors and the board edge, meaning a socket and a transposer on top would probably completely block four ISA slots at the very least 🙁 I asked the guy for a PS/2 card, he gave me a price, I'm considering..
Reply 7 of 8, by maxtherabbit
appiah4 wrote on 2020-07-02, 21:13:
"Almost always" is completely untrue. I'd say less than half of 268/386/468 boards locate it there.
The interposer also doesn't block the cards that don't jut down below the top of the isa slot between the slot edge and mounting bracket, which are many
The 3d renderings I posted back then were a worst case for size, you can make the thing much shorter with no sockets and short pin headers. I also recently revised it to allow for more clearance for the metal slot bracket itself in certain KBC orientations. The design files for this revision will be available publicly once it's tested
Reply 8 of 8, by cyclone3d
maxtherabbit wrote on 2020-07-02, 21:09:
1) you can swap KBCs 2) ok so what? 3) if you have a physical turbo switch this is a non issue it's only to allow for toggle vi […]
2) ok so what?
6) PCB clears that
But there are going to be a lot of people out there that don't want to mess with modifying a board and/or don't have the skills or tools to do the soldering... especially unsoldering the KBC.
That being said, I might mess with doing it that way on systems I build. And I have an idea that would not require unsoldering of the KBC unless you have to swap it.
YMF7x4 Guide
