First post, by Tomsmate
i am using a dynamic CPU core and 3000 cycles, but civilization wont run. can any1 help me?
tried it with a normal core as well ?
Water flows down the stream
yeah it quits with a CPU:GPR5 error, full core comes up with Illegal opcode as well.
Strange, civ works fine for me... tried simple or full cores?
yeah, they all crash. Here is my config:
fullscreen=false
fulldouble=false
fullfixed=false
fullresolution=1024x768
output=surface
hwscale=1.00
autolock=true
sensitivity=100
waitonerror=true
priority=higher,normal
mapperfile=mapper.txtlanguage=
machine=vga
captures=capture
memsize=32
frameskip=0
aspect=false
scaler=none
core=normal(tried all cores)
cycles=3000
cycleup=500
cycledown=0
nosound=false
rate=22050
blocksize=2048
prebuffer=10
mpu401=true
intelligent=true
device=default
xms=true
ems=true
config=
type=sb16
base=220
irq=7
dma=1
hdma=5
mixer=true
oplmode=auto
oplrate=22050
are you certain that your civ isn't messed up (like a bad crack ?)
im sure, ive had it running on an old 100mhz p1 that ive also got. i just want it running in DosBox incase the 100mhz one blows up
I just tried it.
civ.exe
select vga
select soundblaster
select mouse+keyboard
press esc
press with mouse new world
then intro starts
thanks, its working now
care to tell us what was wrong ?
i dont really know, but pressing escape seemed to work
