First post, by RiP
Does anyone know the model of this OPTi 82C495SLC motherboard? 😕
Reply 2 of 21, by evasive
If there's no other markings, from the color/design it looks like a Soyo motherboard that has lost its paper sticker (yes, Soyo is using paper stickers at the time as only means of labeleing/marking! ).
This would mean we need the bios to wake up, for that you need to put back the oscillator that is missing from the socket near the bottom. Do you have an eeprom reader?
Reply 5 of 21, by Deksor
There's sticker on the side of the bottom ISA slot, can you show us what it says ?
Reply 7 of 21, by RiP
evasive wrote on 2020-07-08, 10:12:
I installed 66MHz oscillator and 386DX. The board is running fine but there is no motherboard model in the BIOS.
386SX wrote on 2020-07-08, 10:06:
Are there any codes on the back side of the PCB? Anyway great mainboard.
No.
Deksor wrote on 2020-07-08, 13:38:
It's broken.
Reply 8 of 21, by Deksor
RiP wrote on 2020-07-09, 08:12:
If it's a Ami bios or award, then there is ! Take a picture of the POST screen please ^^
Reply 9 of 21, by RiP
Here you are:
    104.44 KiB
    78.23 KiB
    243.86 KiB
Reply 10 of 21, by Deksor
According to the POST string shown at the bottom of the POST screen, this is made by "TAKEN CORPORATION", whoever they are ...
Reply 11 of 21, by evasive
there's 4 Taken Corporation motherboards in TH99 but all is socket7 or newer.
archive.org is showing only 486PCI and newer...
https://web.archive.org/web/19970416201600/ht … .tw/CATALOG.HTM
Dang, how close can you go:
https://www.elhvb.com/webhq/models/486vlb3/opti495.html
Do the jumper names match even a bit? It looks like boards from this era have been relabeled all over the place, maybe we can pry a manual from one of the other brands.
Reply 13 of 21, by Deksor
Could you please dump the bios so we can add your board to ultimateretro.net ?
For the jumper settings, I don't think there's much to do except figuring out the settings yourself. If you can find which pin goes where, maybe some of us could help you. Cache settings probably go to the main chip of the chipset whereas CPU select stuff probably go to the CPU sockets.
Depending on which pins we might be able to determine how to configure the board
Reply 14 of 21, by RiP
Deksor wrote on 2021-12-24, 00:00:
I don't have a programmer.
I really want to add 486DLC with 256KB cache but it's configured for 386 and 128KB cache 🙁
    1.99 MiB
Reply 15 of 21, by Deksor
You don't need a programmer to dump a 64kb or less bios (which is your case) 😀
Disable shadow bios in the CMOS setup if it's enabled and then run this program http://cd.textfiles.com/microhaus/mhblackbox3 … MORY/GETROM.ZIP
Reply 16 of 21, by RiP
Deksor wrote on 2022-05-06, 09:17:
Here you are:
    ATROM.zip
    42.33 KiB
    48 downloads
Reply 18 of 21, by evasive
evasive wrote on 2020-07-08, 12:54:
@pano69: you seem to have a DataExpert EXP-3406
https://th99.classic-computing.de/m/C-D/31975.htm
This is a different brand most likely.
QDI to be exact: https://www.ultimateretro.net/en/motherboards/5380
Reply 19 of 21, by evasive
RiP wrote on 2022-05-23, 17:48:
Here you are:
Made a page for it:
https://www.ultimateretro.net/en/motherboards/11527
