First post, by TOOL
Where can i find drivers and latest version of bios for this mobo?
Reply 3 of 9, by Horun
Nice collection of DFI BIOS files, would be nicer if it had a readme that helped decode which was what. Each .IMA inside is a floppy bootable image with BIOS and Flasher. Which DFI LANPARTY UT X48 do you have ? T2R, T3RS, etc ? I found multi BIOS images but need more info ...
Also: which BIOS do you currently have ?
Reply 4 of 9, by TOOL
DFI LANParty UT X48-T2R
bios: 12/24/2008-Bigby-8a79pd4cc-00
Reply 5 of 9, by TOOL
The problem is bios won't remeber my settings...
Reply 6 of 9, by TOOL
Tried couple of bioses and no luck. It's the same thing with every bios it won't remember my settings. I even clean bios chip with some isopropil alch.
Reply 7 of 9, by jesolo
TOOL wrote on 2020-10-02, 16:15:
How old is the coin cell backup battery on the motherboard? Might be time for a new one?
Reply 8 of 9, by TOOL
Tried a couple of them, even measure voltages on them and they are all fine...
Reply 9 of 9, by Warlord
sure that your clear cmos jumper isn't on.
