First post, by Aublak
Hello everybody. New guy here.
I think Vogons is pretty great. I really like browsing the forums and seeing all of the interesting hardware for people to show off. I heard a lot about this place through Phil's Computer Lab.
Anyways, I bought a Diamond Monster II 8mb (first working Voodoo card) and everything seems fine with it at visual inspection. I'm using a passthrough cable with my Geforce3 ti200. I installed the official Diamond drivers. Restarted the computer. The Voodoo2 is detected in Device Manager. Fantastic. But it seeming it doesn't work beyond being detected. If I attempt to play Half-Life through the 3DFX mini driver, it just hangs there on a loading screen. Card doesn't seem to get hot at all.
If I go to Properties, I get an error saying 'Diamond Monster 3D II not found. Contact Diamond Technical Support.' Then another error saying 'cocreate instance failed' 'class not registered'.
I dunno. I never had an accelerator card before. Am I doing something wrong or is the card kaput?
Reply 1 of 6, by wirerogue
try checking the box "disable voodoo2 direct 3d support" in your voodoo2 display properties, so the cards don't interfere with each other in D3D.
10.48 KiB
Reply 2 of 6, by Aublak
wirerogue wrote on 2020-07-08, 23:29:
Oh, thanks. I'll give it a shot. But now I have more questions.
It seems like I found another problem. Some components are missing here on C53. What are these? Diodes? I have recently been soldering capacitors back on so I might be able to fix it.
I also have a pair of broken Creative Labs V2 I could potentially cannibalize. One has broken PCB "connectors" and the other one has broken connectors on one of the main chips. I don't think either of these are salvageable, right? I can at least steal some of the ram chips to upgrade my 8mb Monster to a 12mb Monster, right? There's no penalty to mixing ram chips. I believe they all work the same way.
Reply 3 of 6, by Gamecollector
1) HL and HL engine games freeze on the loading screen if a game was started from the autorun.
2) Use something simple to test the glide API. Tech demos as the example.
Reply 4 of 6, by Aublak
Alright. I got her working now. This is very cool. 😀
Which drivers are you using, Wirerogue? I'm not seeing the option to disable D3D. I believe I'm using the latest reference driver.
Reply 5 of 6, by wirerogue
Aublak wrote on 2020-08-03, 00:45:
those were the monster 3d drivers.
you can accomplish the same thing with powerstrip if your voodoo drivers dont' have that option.
Reply 6 of 6, by Aublak
wirerogue wrote on 2020-08-03, 15:03:
very cool. I didn't even know about Powerstrip. This little program is a gamechanger.
the popups are annoying though.
