First post, by DracoNihil
- Oldbie
Does such a thing exist? The joystick I use (Logitech Xtreme 3D-Pro) is right-handed only.
I basically want a robust joystick that atleast has POV hat switch, and rudder/twist control. And the joystick itself should be fully ambidextrous where it doesn't matter if you hold it in the left or right hand.
I primarily want this so I can better play Gunmetal, but I also would like such a joystick so I can better control Urban Assault, with joystick control on the left hand and mouse micromanagment on the right. (I am primarily right handed, but I can handle a setup like this)
I tried searching around myself but I end up finding dodgy user reviews mentioning everything from potentiometers failing within a year of usage or other significant wear and tear occuring without even roughhousing the joystick itself, so I'm really conscious of not wanting to waste $100 on something that'll practically break by me just looking at it strangely.
