First post, by guest_in_despair
I hate windows XP, I start dosbox there is a black screen for about 10 seconds then it goes away and the program closes... help me please.
Reply 1 of 4, by HunterZ
Post your system specs. Post your dosbox.conf. Read the posting guidelines. We don't have enough information to help you 🙁
Try running in a window instead of full-screen.
Reply 2 of 4, by Snover
My magical sense of direction (and log grepping) indicates you are an Internet Explorer user. I would suggest cleaning your spyware and switching to a more reasonable browser. 😀
Yes, it’s my fault.
Reply 3 of 4, by HunterZ
Heh. It'd have to be pretty bad for spyware to be causing DOSBox to crash, but I've seen worse.
Reply 4 of 4, by eL_PuSHeR
Spyware/malware causing troubles? It could be very possible. Anyway i should check DOSBox configuration first, specially the rendering modes. 😎
