First post, by Deksor
Hello !
I have this PcPartner motherboard which POST without any problem except the keyboard doesn't work ...
I can see the LEDs flashing so the fuse is good and the keyboard is properly powered. I sprayed contact cleaner in the kB connector just in case, but it didn't work ...
What should I consider next to try to fix it ? I am out of ideas ... Do you see any flaws on the PCB ?
Reply 1 of 3, by Roman555
Deksor wrote on 2020-07-10, 16:25:
Hello ! […]
Hello !
Hello!
There's a scratch on the bottom
    194.7 KiB
[ MS6168/PII-350/YMF754/98SE ]
[ 775i65G/E5500/9800Pro/Vortex2/ME ]
Reply 2 of 3, by Deksor
Oh wow good catch !!
This trace was indeed cut. After fixing it, the keyboard worked 😀
Thank you so much 😁
