Windows 3.1 in 256 colours
Developer's Forum, for discussion of bugs, code, and other developmental aspects of DOSBox.
Postby canadacow » 2004-12-22 @ 11:01
CVS 12-22-2004
Includes almost complete emulation of video emulation needed for the S3 Windows 3.1 driver. There are still some bugs remaining but the interface is usable and stable
Following link is the driver needed, S3 864 v1.41B5
864141b5.zip
http://www.winsite.com/bin/Info?4009
I've only tested 640x480 and 800x600 in 256 colors using SF or LF modes.
You may have to skip the Windows splash screen by running, "win /b".
User avatar
canadacow
Re: Windows 3.1 in 256 colours
Postby Qbix » 2004-12-22 @ 20:17
I get a lot of pagefaults when exiting windows.
futher than that it seems to work. with 3.1 and 3.11 for workgroups
pagefaults are in b9000 and alike......
Water flows down the stream
User avatar
Qbix
DOSBox Author
Postby gulikoza » 2004-12-22 @ 21:56
I get a lot of exceptions (or illegal opcode with full core) when running in enhanced mode. Plus it seems the mouse stopped working when I installed SB16 drivers. Standard mode is fine, other than that I too have a feeling mouse is mooving faster in X direction than Y. Somewhat annoying...but still, great job!
User avatar
gulikoza
Postby Srecko » 2004-12-23 @ 02:41
Mouse cursor problems (WfW 3.11):
- if moved over a window border, disappears for a short moment
- menu item (e.g "exit windows") is selected only if I click on a lower part of it's text (i.e. cursor misplaced ?)
- edit:minesweeper:problem also caused by misplaced cursor
All those don't appear with vga 3.0 driver.
Also, mouse moving is about twice as fast in X axis direction than in Y.
Srecko
Postby canadacow » 2004-12-23 @ 03:20
I was aware of the mouse issue when I posted it to the CVS :disapproving: . It has to do with the raster drawing code being ambiguous as to what line its on.
The following lines of code are the offending parts: Qbix, Harekiet, what is the proper method for detecting what line the video card is on?
Code: Select all
static Bit8u * VGA_Draw_VGA_Line_HWMouse(Bitu vidstart, Bitu panning, Bitu line) {
   if(vga.s3.hgc.curmode & 0x1) {
      Bitu lineat = vidstart / ((160 * vga.draw.height) / 640);
      //Bitu lineat = vidstart / 160;  160 works only for 640x480
User avatar
canadacow
Postby canadacow » 2004-12-24 @ 05:36
Doh. Fixed my own problem. Just committed some final patches to the S3 XGA code to the CVS tree. In particular, this should fix the mouse problems. Let me know if you guys see any other visual anomalies.
User avatar
canadacow
Postby Qbix » 2004-12-24 @ 08:07
the mouse pointer and it actions behave much better.
User avatar
Qbix
DOSBox Author
Postby HunterZ » 2004-12-26 @ 18:02
Does this mean that the vertical mouse movement speed problems I've encountered in other DOS games under DOSBox might be fixed now too?
You're perfect, yes it's true...but without me, you're only you.
User avatar
HunterZ
Postby canadacow » 2004-12-26 @ 18:11
No... this was an S3 XGA hardware mouse acceration improvement only.
User avatar
canadacow
Postby Qbix » 2004-12-26 @ 18:27
HunterZ wrote:Does this mean that the vertical mouse movement speed problems I've encountered in other DOS games under DOSBox might be fixed now too?
If you can provide a complete list of games that "suffer" from it I will/can/might fix it.
User avatar
Qbix
DOSBox Author
Postby HunterZ » 2004-12-27 @ 02:13
Qbix: so far I've only had problems with Elder Scrolls: Arena. The mouse seems to "stick" on certain scanlines when I move it in a vertical fashion.
User avatar
HunterZ
Postby JimLarimore » 2004-12-29 @ 00:34
Ack. The Dig and Full Throttle as well.
-Jim
JimLarimore
Postby priestlyboy » 2005-1-02 @ 05:19
It seems that Quicktime for Windows 2.11 (I was tring it with a game I Have) crashes Windows 3.1 with X3 VGA drivers.
Some Illegal Opcode I believe in the latest Version of DOSBox from the CVS.
I'll have to double check though but that's what I'm getting. When I use the VGA driver w/ Quicktime 2.11 everything runs okay.
I'll try a newer version of quicktime but I know it works with the other VGA 3.0 or VGA drivers.
These are though what I saw for 90% of the log that I dumped before it dumped out of Windows 3.1 into DOS.
43727096: CPU:Illegal Unhandled Interrupt Called 6
43727098: CPU:Illegal/Unhandled opcode 63
It just showed that over and over and over.
Ieremiou
Helping Debug DOSBox.
User avatar
priestlyboy
Postby ninjalj » 2005-1-13 @ 19:17
That is windows in enhanced mode, isn't it?
INT 6 and opcode 63h (c of ROM BIOS copyright string) are "breakpoints" the VMM puts on real mode code. They cause an exception that should redirect execution to the VMM (through the IDT)
User avatar
ninjalj
Postby wd » 2005-1-13 @ 21:25
The exception handling (and VMM callbacks) work as they should.
Iirc. the message priorities were lowered some time ago so they
shouldn't appear any more.
Anyways, as you said they are intentional (and crucial for
enhanced mode to work).
wd
wd
DOSBox Author
Postby kekko » 2005-1-26 @ 16:11
With "normal" core win3.11 installs and works perfectly; audio, video and all.
But with "dynamic" core it shows this message at startup and the audio doesn't work anymore.
I'm using latest cvs + sdl1.2.8. + vc.net 2003
(21.24 KiB) Downloaded 1981 times
User avatar
kekko
Postby wd » 2005-1-26 @ 17:34
It is not supposed to work, and it won't work.
wd
DOSBox Author
Postby priestlyboy » 2005-1-26 @ 18:34
Thanks for the exception fixes wd. Quicktime runs properly now in enhanced mode. :)
I can now play an old game called Castle Explorer in 256 colors. Yes an educational game but a fun one.
/Ieremiou
Ieremiou
User avatar
priestlyboy
Postby cyberwalker » 2005-7-14 @ 07:07
canadacow wrote:The latest CVS build includes almost complete The driver needed is S3 864 version 1.41B5 and its available from an archive named 864141b5.zip . You should be able to get it here:
The only two tested (and the only modes that should work) modes are 640x480 with 256 colours and 800x600 with 256 colors (either SF or LF modes are fine).
I encountered problem in 640x480 with 256 colors, but it seems 800x600 with 256 colors(LF) is fine.
cyberwalker
Postby waw_demmon » 2005-10-08 @ 16:27
Does'n work
the mouse freeze and cursor is a big black scare
please Helps me :depressed:
chek my screen
(60.88 KiB) Downloaded 2021 times
waw_demmon
Next
Return to DOSBox Development
Who is online
Users browsing this forum: No registered users and 0 guests
