First post, by Jonas-fr
Is there any known DOS utility that doesn't use INT13H to access a disk allowing one to browse its files without said HDD to be seen/declared in the BIOS?
I know for a fact that IDEINFO doesn't depend on the BIOS since it can detect IDE drives by querying the bus directly (this in this case letting one's know about a HDD geometry) and without said HDD being declared in the BIOS. Testdisk also uses its own routines but not on the Win9x/DOS version (it is INT13H dependant). The goal of such an utility will be to be able to access files on the motherboard with a dead battery/broken CMOS circuit. This is more a thought experiment than anything else since one can move the HDD on a functioning mobo but bear with me : )
Such utility would be a nice addon for "the all in one floppy"
Reply 1 of 4, by Jo22
Jonas-fr wrote on 2020-07-14, 19:51:
Well, most DOS programs call DOS int21h to access a disk - which in turn calls int13h mainly..
Some disk utilities like DEFRAG ((MS, Symantec), COMPRESS (PC-Tools) and so on also access the disk directly (by-passing DOS), albeit via int13h..
The only "DOS program" I know of which does access a HDD directly is WfW 3.11 with FastDisk driver.
Once virtual memory (permanent swap file), the HDD driver and the drive cache are all enbabled, WfW is entirely self-reliant.
It will nolonger call DOS or BIOS to do it's work. In this state WfW also will emulate int13h for applications then.
That being said, you might also want to have a look at the attachment..
- It describes how DOS retrieves drive geometry information. 😀
    GT1024.ZIP
    17.34 KiB
    95 downloads
    Direct DOS 5.0 support for disks with more than 1024 cylinders.
Reply 3 of 4, by verysaving
take a look at DMDE
https://dmde.com/download.html
there's a version working in DOS, and you can
select a direct IDE mode when accessing the disk.
It's not properly a browser but a data recovery software,
but it can be uses to view files and supports a lot
of file systems.
To test disk directly even ignoring BIOS you can use
MHDD
https://hddguru.com/software/2005.10.02-MHDD/
or VICTORIA
https://hddguru.com/software/2005.10.03-Victoria/
both excellent programs.
