First post, by gaffa2002
Hi again,
It seems that my Epox EP-7KXA motherboard has a bad bios chip, for no aparent reason, I started getting this error message:
BIOS ROM checksum error
Detecting floppy drive A media...
INSERT SYSTEM DISK AND PRESS ENTER
I can't POST or enter setup, after some work I was able to boot from a floppy drive and attempted to use many different versions of AWDFLASH in order to load the bios image again but without success. Also tried UNIBIOS and when I forced to flash the bios image I had, there were a lot of errors while attempting to flash so that's why I suspect the chip is bad.
Now I want to replace the BIOS chip, but I simply cannot find one with the exact same model to buy (its an EON EN29F002NT-70P). Question is, do I really need to buy the exact chip or can I use a different one as long as it is DIP32 and has 2Mbit (or even larger)? If yes, what should I search for when purchasing a replacement chip?
Thanks in advance!
    714.04 KiB
LO-RES, HI-FUN
My DOS/ Win98 PC specs
EP-7KXA Motherboard
Athlon Thunderbird 750mhz
256Mb PC100 RAM
Geforce 4 MX440 64MB AGP (128 bit)
Sound Blaster AWE 64 CT4500 (ISA)
32GB HDD
Reply 1 of 7, by adalbert
Find the datasheet for that chip and check what voltage it is, probably 5V. Find another chip and compare datasheets: is the voltage the same and is the pinout the same. You don't need to have exact same chip, but it needs to be programmed before you use it. Sometimes you can even use larger chip, but you need to flash multiple copies of BIOS so it fills the entire space.
Reply 2 of 7, by Deksor
I've noticed that 29EE010 chips work well with most Pentium/Pentium II motherboards.
Reply 3 of 7, by adalbert
BTW how will you flash the new chip? If you don't have external programmer it is theoretically possible to hot swap chips after you boot into flash utility. But there is risk of damaging stuff.
Reply 4 of 7, by gaffa2002
adalbert wrote on 2020-07-15, 20:26:
Thanks everyone for the replies.
I plan on using UNIBIOS since I can still boot from a floppy. The motherboard has the bootblock bios, and by using a fake modified version of AWDFLASH I could boot to a command prompt. But as per your response I understood I need the exact same chip to be able to do that, other brands will require me to flash it somewhere else before plugging it in.
I also have another motherboard, a V72MA which also uses an 2MBIT DIP32 chip. I though about canibalizing its chip in order to restore the 7KXA (i.e forcing it to flash the 7KXA bios into its own chip), but I really don't want risk having two broken motherboards instead of one.
LO-RES, HI-FUN
EP-7KXA Motherboard
256Mb PC100 RAM
32GB HDD
Reply 5 of 7, by adalbert
gaffa2002 wrote on 2020-07-15, 20:33:
I plan on using UNIBIOS since I can still boot from a floppy. The motherboard has the bootblock bios, and by using a fake modified version of AWDFLASH I could boot to a command prompt. But as per adalbert response I understood I need the exact same chip to be able to do that, other brands will require me to flash it somewhere else before plugging it in.
Even the same chip could have different BIOS flashed or be empty, so the model doesn't matter. If that motherboard has functionality of booting from floppy with BIOS chip removed (I don't know if that's even possible) you might be able to flash any chip. But if it's not possible, then you need to find a way to flash new chip. This is what I did some time ago:
- original BIOS chip is in motherboard
- I booted from floppy into flash utility
- I removed BIOS chip while computer was working (that's the dangerous part)
- inserted new BIOS chip (it was a different model)
- flashed it
it's best to do that on a spare motherboard which is not valuable. In theory you could flash any BIOS on any motherboard and replace the chips afterwards.
Reply 6 of 7, by gaffa2002
adalbert wrote on 2020-07-15, 20:50:
Even the same chip could have different BIOS flashed or be empty, so the model doesn't matter. If that motherboard has functiona […]
- flashed it
Just tried the hot-swap method you suggested on the V72MA using the EP-7KXA chip which I assumed was broken, and the flashing WORKED! Issue was on the flashing process and not on the chip apparently, both motherboards survived and now everything is booting fine. My Windows 98 machine is finally back from the dead 😀,
Thank you so much for the suggestion!
LO-RES, HI-FUN
EP-7KXA Motherboard
256Mb PC100 RAM
32GB HDD
Reply 7 of 7, by adalbert
That's a great news, I'm glad it's working 😀
