PC-104 board found
First post, by 19rsn007
Hi people,
I found a PC-104 board with a 386SX @40MHz with some ram which does power up but since it has no video output I can not see what it does.
It does beep, 2 short beeps then a short pause and then 8 short beeps.
Google found me this is either ram or videocard.
The last option sound reasonable to me, since it doesn't have a videochip on board or an external videocard.
I have an old ISA videocard (acumos avga2) which I don't know if it is working and an old 486 motherboard with bad battery leakage damage.
Now I am considering to build a PC-104 to ISA adapter so I can test it.
should I do this?
If it works I am thinking about building a ISA backplane for the PC-104 bus.
Reply 1 of 9, by imi
doing an ISA to PC/104 adapter should be very straightforward, as they're basically the same ^^
the pinouts of both align as well, making it even easier.
Reply 2 of 9, by dionb
On a similar note: is there a specific term for PC/104 cases? I'd like to build myself a little stack of PC/104 hardware, but despite this being an old and much-used standard, I'm not having any luck finding things to build it in...
Reply 3 of 9, by imi
I don't think there would be any specific term but "PC/104 case", these weren't really meant to go into cases anyways but to be used in other industrial or automotive equipment mostly.
Reply 4 of 9, by Marco
386sx40? That’s new to me. Always thought they were built up to 33 only
1) VLSI SCAMP 311 | 386SX25@TI486SXLC2-50@63 | 16MB | CL-GD5434 | CT2830| SCC-1 | MT32 | WDC160GB/7200/8MB | Fast-SCSI AHA 1542CF + BlueSCSI v2/15k U320
2) SIS486 | 486DX/2 66(@80) | 32MB | TGUI9440 | LAPC-I
Reply 6 of 9, by debs3759
386SX40 was only produced by AMD, and was QFP (ie soldered to the board)
Reply 7 of 9, by Tiido
PC104 to ISA is indeed quite straightforward :
http://www.tmeeco.eu/BitShit/PC104toISA.jpg
http://www.tmeeco.eu/BitShit/PC104internet.jpg
I upgraded one 386SX board to a 40MHz one not so long ago :
http://www.tmeeco.eu/BitShit/PCschit/SX25toSX40a.jpg
Reply 8 of 9, by pentiumspeed
I done that same way except on a compaq LTE 386s/20 using a AMD 386SX-25 and clock generator oscillator changed and that was back in the day (around early '94)!
Cheers,
Great Northern aka Canada.
Reply 9 of 9, by Marco
Respect for getting this soldered !!!
my sx25 vlsi board won’t exceed 30MHz unfortunately.
