First post, by Václav Steiger
Hello,
I'm dealing with a little bit special use case for DOSBox. I'm trying to run an old DOS FoxPro app in DOSBox on Windows server, and then I'm publishing the DOSBox as RemoteApp for users to connect to it from their computers. I have prepared autoexec portion of the config file to automatically run the FoxPro app, then I added -conf parameter with path to this config file. This is actually working fine, when I click on it, I log in with my user credentials and then DOSBox window shows up with the app. In the console I can see It loads and uses my special config file. All is good.
Howewer, when I try to log in as another user, who wasn't logged on the server yet, DOSBox autogenerates new config file in C:\Users\<new_user_name>\AppData\Local\DOSBox.conf and uses only it - and not my previously prepared config file, so it does nothing, just hangs with Z: prompt.
Is there any way to prevent this behaviour?
Thanks in advance
V.Steiger
