First post, by AuxNuke
I'm using an Epox EP-MVP3C2 for a nice Super Socket 7 build. It appears that the PS2 header has a proprietary pinout:
Does anyone know the order for Data, VCC, CLK, and Ground?
Or anyone with this board and the included PS2 header able to map out which pin on the motherboard header goes to which pin on the PS2 port?
-Retro-
AMD K6-III+ 450ACZ @ 550MHz 2.1V
384MB (3 x 128MB) Infineon PC133 @ 100MHz CL2
Epox EP-MVP3C2
Diamond V770 32MB TNT2 AGP @ 150/170
Sound Blaster Live! CT4760
40GB WesternDigital Caviar 7200rpm
Netgear GA311 NIC
