First post, by deksar
Greetings.
I'm looking for a HDD alternative for my IBM PS/1 Model 2011.
I wanted to ask, would a DOM drive (attached image) work with that PC? The mainboard has 44-pin HDD connector (XTA with power pins).
Documentation link: https://ps1stuff.wordpress.com/documentation/ … ps1-model-2011/
It has also a serial expansion board, that has male floppy power output. If DOM wouldn't be compatible, would modding IDE data cable (eliminating power pins) and getting HDD power externally from that serial exp. board work?
Many thanks for your replies and ideas in advance,
Best.
    25.01 KiB
