First post, by kingcake
I want to take a stab at making my own ISA card. Just a simple diag card.
Anyone else done this before?
I thought it would be easy to find an ISA template for altium or easyeda or something, but I'm not having much luck.
Reply 1 of 7, by adalbert
Sure, there are such projects:
http://www.malinov.com/Home/sergeys-projects/isa-opl2-card
https://www.glitchwrks.com/xt-ide
https://www.lo-tech.co.uk/tag/xt-ide/
Blasterboard : A SB 2.0-compatible ISA sound card
Arrived ISA 8 bit NE2000 network adapter boards
https://www.vladimirov.org/
i didn't design one myself, but I home-manufactured working adlib clone using schematics from first website
AT(X)Anything: a modular DC-DC PSU for old PCs (open hardware)
Reply 2 of 7, by maxtherabbit
If you work in kicad I can share the design files for a proper edge connector with you
Reply 3 of 7, by kingcake
maxtherabbit wrote on 2020-07-28, 20:24:
that's what I'm looking for! Yes, please.
Reply 4 of 7, by maxtherabbit
My edge connector is attached to this post. The footprint for the actual contact fingers was included with kicad, but the keep out zones and edge cuts are my original contributions. This will prevent auto routers from trying to place traces or vias on the edge connector as well as properly pulling back the soldermask off the edge. It's designed to accommodate proper beveling and hard gold plating if desired, to facilitate a truly professional design. If you use it in a product, I ask only to be credited.
Reply 5 of 7, by kingcake
maxtherabbit wrote on 2020-07-28, 23:08:
Of course!
How do you want to be credited?
Reply 6 of 7, by maxtherabbit
idk just be like thanks to maxtherabbit for the edge connector design in your documentation or release notes or whatever
Reply 7 of 7, by Cyrix200+
I once had the idea to design an ISA POST analysis card, but later decided to use my time on other things for now 😀 I do have a bunch of notes though. These two sites have similar projects:
http://www.malinov.com/Home/sergeys-projects/isa-post-card
http://bbright.tripod.com/information/postcard.htm
There also is a design in a 1995 issue of Elektuur/Elektor magazine (I have scans of the Dutch issue, but I know it's also available in English). It uses a GALs and I have not been able to find the code for those unfortunately. Wikipedia uses a picture of that card: https://en.wikipedia.org/wiki/POST_card#/medi … S_POST_card.jpg
1982 to 2001
