First post, by vr041
I'm having problems with flickering on Wrath of Earth on Dosbox 0.74-3, running an Intel i7-8565U, with 4gigs of ram with 16 gigs of optane, and using a GeForce MX130. The opening cutscenes and intro all display fine, but when I get into the core gameplay itself, I get flickering in the form of thick black lines, mainly in the middle of the screen. I've tried both the svga_s3 and vesa_nolfb for the machine setting, both openglnb and surface for the output setting and operating with full resolution set to both true and false.
If anyone can give me a heads up if there's something I'm not doing that I need to do (I already had to set EMS to false and as a precaution for low memory, I set the memsize to 64), I'd greatly appreciate it.
Edit: warez link removed
Reason: Removal of warez link
Reply 1 of 3, by ripsaw8080
Rank DOSBox Author
DOSBox Author
Please do not post links to downloads of copyrighted software here.
Try 10K fixed cycles for the game (cycles=10000), maybe a bit more or less depending on your system, but too many cycles will cause flickering.
Reply 2 of 3, by vr041
Sorry, I was under the impression that the game was abandonware which as I understood it, meant public domain. I'll bear that in mind going forward. Thanks for that - looks like it did the trick.
