First post, by tomexplodes
Device manager lists it as HL-DT-STCD-RW GCE-8483B. Windows recognizes it as a CD-ROM drive only. ImgBurn doesn't find it at all. It finds my DVD-ROM drive no problem, but can't see the secondary drive.
The drive itself works to read CDs just fine.
Everything is plugged in properly, both drives are set to cable select. If there is a driver for it, or a generic CD-RW driver somewhere, that would be great. That's about it. Thanks in advance!
1.) MS-DOS 6.22, Pentium-S 90mhz, 32mb RAM, S3 Trio64, Vibra 16
2.) Windows XP, AMD Athlon XP 3000+ 2.1ghz, 512mb RAM, Geforce 4 TI 4200 128mb, Sound Blaster Live! Value
Reply 1 of 6, by tomexplodes
OKAY. Sorry, I think the problem is with ImgBurn. It's only recognizing my G Drive, which is my virtual DVD-ROM drive. So there's that. My bad.
EDIT: I forgot to install ASPI. I'm stupid. This thread is stupid. Please remove. Thank you! I am stupid!
Reply 2 of 6, by Horun
tomexplodes wrote on 2020-08-02, 02:22:
No actually that is a common mistake and thanks for posting about it ! It will help remind us about it. Thanks 😀
Reply 3 of 6, by darry
Horun wrote on 2020-08-02, 02:33:
I agree that it is a good reminder . I have not burned a disc under Windows 9x in over 15 years . If I ever need to do so again, I have a better chance of remembering ASPI thanks to this thread (though I think I still have a sealed boxed copy of Adaptec CD Creator 4 that I could use that will install ASPI drivers for me if needed).
Reply 4 of 6, by dr_st
Yeah, I also have no memory of this ASPI stuff. Probably because, like many folks, the first burner I had on a Win9x came bundled with software (Nero in my case), which installed the drivers for me.
Reply 5 of 6, by TheStrayChow
@tomexplodes - What ASPI package did you install... im having the same issues on windows 95 with the same CDRW! Any ideas?
Reply 6 of 6, by Horun
For Win98 you should use the Adaptec Aspi 4.7x. If Win95 should be Aspi 4.60.
Here for 4.71: https://storage.microsemi.com/en-us/speed/sof … i_471a2_exe.php
