SYS.COM freezes machine
First post, by kingcake
I'm using a syba cf to ide adapter with a 128M industrial cf card in a packard bell.
I can format and read/write to the card all day long without problem.
But if I run sys a: c: to copy dos boot files to the cf card the machine freezes. The activity light on the syba stays lit indefinitely.
I left the machine for hours and it never times out or gives any error.
I verified the CHS with ideinfo and the bios settings are correct.
Any idea of a workaround for this?
Reply 1 of 10, by Warlord
try command FDISK /MBR then just manually copy command.com, io.sys and msdos.sys
Although I disagree with using dos for formatting and partitioning solid state media. I use other tool for this.
http://wp.xin.at/archives/1449
Reply 2 of 10, by kingcake
fdisk /mbr also freezes the machine
Reply 4 of 10, by aha2940
Maybe the boot sector is protected in the BIOS? it's usually named something about "virus protection".
Reply 5 of 10, by kingcake
Warlord wrote on 2020-08-04, 23:15:
partitioning and formatting is not the issue
Reply 6 of 10, by kingcake
aha2940 wrote on 2020-08-05, 04:36:
not an option in this bios
Reply 7 of 10, by jakethompson1
What about format c: /s
Reply 8 of 10, by matze79
Its called Virus protection some times in bios.
Reply 9 of 10, by debs3759
BIOS virus/boot protection usually displays a message to ask whether you want to proceed or to say the boot sector is protected. Also, if that was the problem, it would not be possible to format the drive.
Reply 10 of 10, by kingcake
Well I figured out a work around. I installed Ontrack driver overlay to see if it's bios extensions would fix the problem...and they did. With ontrack I can sys, format /s fdisk /mbr all day long no problem.
I hate to use a drive overlay when I don't have to, but it fixes the issue with my bios.
