Replace AT PSU with ATX?
First post, by root42
Is it possible to replace an old AT power supply with an ATX on inside of an AT case? Do the dimensions and screws fit?
YouTube and Bonus
Reply 1 of 3, by GigAHerZ
Usually yes.
Only problem really is that newer computers rely on 12V a lot, while good old retro-machines consume mostly 5V rail.
Therefore you need a strong 5V rail on your ATX PSU, which may lead you to buy something like 750W PSU just because it can push out enough amps on 5V...
Reply 2 of 3, by root42
GigAHerZ wrote on 2020-08-06, 15:09:
Usually yes.
Hm, I have one 450W in my 486 ATX tower. Works fine (with the ATX2AT smart converter). Indeed I need around 5A on the 5V and only 0.3A on 12V.
But I have one AT case where I don’t quite trust the supply and would love to have the security of the smart converter as well, since I play around with quite a few homebrew cards.
YouTube and Bonus
Reply 3 of 3, by GigAHerZ
If you keep an eye on your 5V power rail requirements, go for it. Those old AT PSUs are not trustworthy anymore today. 😀
