COM prot problem in XP
First post, by Guest
I posted this problem yesterday but the post disappeared!
I have an old DOS terminal emulation program called QTerm that I need to get running in XP. QTerm uses a polling protocol, so poll response timing is important. Qterm runs in the XP dos-box but it doesn't appear to respond to polls in time, making it unusable. When I run it in DOSBox I get the error (this is not exact)....
Error Exit - PIC: Unhandled command 40
This program runs fine under Windows 98
Please Help!
Reply 1 of 1, by mirekluza
Rank DOSBox Moderator
DOSBox Moderator
It is in DOSBOX Games/Apps and it has more sensible name (with QTerm in it).
You should follow rules of the board. One of them is: App. specific problems should go to DOSBOX Games/Apps !!!
Closing.
Mirek
