First post, by Wilius
Greetings everyone
The problem is as following: I aquired some parts of a 286, which I assume used to be a Schneider VGA AT System 70 CEG. Unfortunately its case and PSU are long gone.  Instead of the typical AT power connectors, it has weird custom ones and I don't have any PSU, which is compatible with these kind of connectors. Sadly, I haven't found a fitting replacement yet. So I suppose, that I have no choice, but to modify a AT/ATX PSU, to work with my system. The thing is, I don't know the pinout. So my question is, can anyone please provide me the pinout for the connectors and tell me (if possible) how to modify a AT/ATX PSU to work with this beautiful relic?
(Let me know if you need more pictures)
Thanks in advance for your help
I apologize, in case, that i'm not replying right away. I'm a bit busy right now. But i'll still try my best, to not let you guys wait.
