First post, by T4600C
I have a Compaq Deskpro with AGP bus running Windows 2000 Service pack 4.
I want to put my Geforce4 4200 Ti inside it. Unfortunately it is causing weird problems with I run Serious Sam First Encounter.
I tried my GeForce4 MX 440SE and it is causing the same artefacts. But with my Geforce3 Ti 200 i get no such problems. This tells me it is a driver-related problem?
I am using Nvidia ForceWare 94.24.
The glitches are smearing effects that seem to randomly occur and disappear. Usually lasting a few seconds and smearing objects, weapons, enemies and buildings. Dont have this with games such as far cry, unreal and quake 3.
Some examples:
1.87 MiB
1.94 MiB
1.72 MiB
1.7 MiB
Reply 1 of 2, by Joseph_Joestar
The drivers you are using are way too new for those cards.
Stick to version 45.23 or below.
Reply 2 of 2, by T4600C
Joseph_Joestar wrote on 2020-08-08, 10:08:
I will try that, thanks.
And because of SS' expansive rendering settings, I was able to narrow down the culprit.
Rendering of lens flares was causing the problems.
