First post, by Intel486dx33
I would like to see photos of you most unique build that you have put together yourself or with help.
A build where you choose the components the way you like it.
Here is mine. Its actually NOT what I like but unique.
AMD 5x86@160 MHz with a Media Vision Pro Audio Spectrum 16 sound card.
AMD 5x86@160mhz., Media Vision PAS16. ( Win 95 )
Reply 1 of 17, by Intel486dx33
My Ultimate Turtle Beach build in Aluminum case.
Re: Ultimate Turtle Beach Build
Reply 2 of 17, by Intel486dx33
My Ultimate Terratec Audio studio build with Super Flower anodized black metal case.
Ultimate Audio / Gaming build - Terratec/SB Audigy2zs
Reply 3 of 17, by Intel486dx33
My Ultimate Multimedia 486 build with Techmedia case.
Runs on 3.1 megabytes or RAM.
486 Multimedia dream build ( 1993/94 )
Reply 4 of 17, by Intel486dx33
AMD K6 3+ OverClocked @ 550mhz. With VooDoo 3000 and Sound Blaster Live 5.1
AMD K6-III+@550mhz., Voodoo-3-3000 (tower)
Reply 5 of 17, by Intel486dx33
AMD K6 3+ Overclocked @ 500mhz. With VooDoo 3000 and AWE64
AMD K6-lll+@500mhz., Voodoo 3000 (desktop)
Reply 7 of 17, by creepingnet
Honestly I'm torn between my Home Brew 486 DX4-100 and NEC Versa M/75
Creeping Net 486 DX4-100
121.07 KiB
CASE: Songcheer/Suncheer XT Clone Chassis
PSU: JDR Microdevices 200 Watt XT PSU
MoBo: FIC 486 PVT Socket 3 w/ Award BIOS
CPU: AMD Am486DX4-100 SV8 w/ Writeback Cache
RAM: 64MB 72 pin FP SIMMS
L2: 512K L2 Cache (5 chip)
FDD: 1.44MB 3.5", 1.2MB 5.25"
HDD: LianLi RH-17 Mobile Rack w/4HDD (8GB MS-DOS/WFW, 80GB SATA Win95 OSR 2.5, 80GB PATA FreeDOS 2.1)
GFX: 2MB S3 805 SVGA VLB
SND: SoundBlaster AWE64 Platinum
NET: Linksys Etherfast PnP 10mbps ISA
KB: IBM Model "M" PS/2 (converted to AT)
MOUSE: Microsoft "Dove Bar"
GAMEPADS: Microsoft Sidewinder 1.0 X2
SPEAKERS: Altec Lanscing (really bassy)
MONITOR: Micron 15" CRT SVGA
NEC Versa M/75
8.88 KiB
NEC Versa M/75
PLATFORM: NEC Ultralite Versa 486 w/ Removable Screen
PSU: Up to 2x 7.2V 3800Mah NiMH Smart Batteries, 45 Watt NEC Versa PSU
MOBO: Versa M-Series Planar with 75 Mhz Board and Memory Add-Ons, Phoenix BIOS
CPU: Intel 80486 SLX DX4-75
RAM: unknown L2 Cache, currently 24MB, eventually will be 40MB though (with 36MB Upgrade)
FDD: Ordering a 1.44MB 3.5" Drive for it eventually
HDD: 2 "Drive Paks" - 244MB Drivespace'd HDD (original, MS-DOS/WFW), 80GB PATA w/ DDO
GFX: Chips & Technologies 1MB SVGA w/ NEC NL6448AC30 640x480 TFT Active Matrix LCD
SND: WSS Compatible Crystal CS2431 Chipset Audio or "Crystal Business Audio" as it's called
NET: Cisco Aironet LMC-350 WiFi card tethered to my Cell Phone over Hotspot (only on when I want it)
O/S: Triple Boot off the 80GB - MS-DOS 7.11 (win98SE) triple boot with Microsoft Windows For Workgroups 3.11 and Windows 98 SE - with some pieces of FreeDOS hacked in
It's got a docking station coming in which will liklely be using my Model "M" and NEC Logitech Mouse with the same monitor as the 486 Desktop above.
~The Creeping Network~
Reply 8 of 17, by Intel486dx33
My Ultimate Pure DOS gaming computer. Pentium MMX 233 with Sound Blaster AWE64.
DOS Cadillac gaming computer.
Cowboy Coffee build.
Pentium MMX-233 DOS gamer dream machine.
Reply 9 of 17, by jheronimus
Intel486dx33 wrote on 2020-08-12, 09:25:
My Ultimate Pure DOS gaming computer. Pentium MMX 233 with Sound Blaster AWE64. […]
Are you photoshopping case badges? Why? 😀
MR BIOS catalog
Unicore catalog
Reply 10 of 17, by adalbert
Old photo so I probably posted it somewhere already, but it fits the topic since I made this case so it's certainly unique 😁
currently it has K6-2+, Voodoo Banshee and probably ESS ISA Soundcard. I also used this case with 4DPS tomato board. Now there is some kind of SS7 board with similar size.
Reply 11 of 17, by wiretap
adalbert wrote on 2020-08-12, 11:33:
That's probably one of my favorite custom builds I've seen here. After seeing it, I actually purchased some white plexi to build a case for a mini Philips 10MHz 8088 motherboard I have.. still need to get around to it.
My Github
Circuit Board Repair Manuals
Reply 12 of 17, by ildonaldo
Currently, my most unique build is the #3 from the signature
PC #3: AthlonXP 3200+/nForce2-400/2GB-400 DDR1/9800Pro/ZIP 750/200GB HDD/ODD/WIN XP SP3
It is of sentimental value to me because the main parts are all original from my old PC.
Lately I've added the silver Lian Li case and the L.I.S. 2 indicator.
Both are period correct and match beautifully.
50.29 KiB
AthlonXP 3200+ with L.I.S. 2 indicator
GPL-2.0-or-later
Building my own PCs since 1991 - for my retro builds it's "no CF-disks, no Floppy emulators, no modern cases etc.", only the real and authentic stuff whenever possible.
Reply 13 of 17, by chrismeyer6
ildonaldo wrote on 2020-08-17, 14:46:
Currently, my most unique build is the #3 from the signature PC #3: AthlonXP 3200+/nForce2-400/2GB-400 DDR1/9800Pro/ZIP 750/200G […]
That really is a very beautiful system you built.
Reply 14 of 17, by audiotechnica
wiretap wrote on 2020-08-11, 17:58:
Just rename the thread to "Look at all Intel486dx33's computers".
But do they all run like Cadillacs? They better be all Cadillacs or GTFO.
Reply 16 of 17, by Hezus
That's a really cool case! How did you build it?
Visit my YT Channel!
Reply 17 of 17, by adalbert
Hezus wrote on 2020-08-24, 06:40:
Thanks 😀 I used 3mm thick HIPS sheets, 20x30cm in size, sides are made of entire uncut sheets, and I cut top, bottom and front to adequate size. This is done by hand, by cutting the sheet few times and breaking it. I 3D printed ventilation cover and angle bars (for sticking different parts of case together), CD-ROM mount, floppy mount and mainboard screw holders. 3D printed mounting parts were glued to HIPS pieces using cyanoacrylate glue. LED indicators are covered with black print on a tracing paper. I would like to make a slightly larger case with laser cut parts and frame made of metal bars, but there is never enough time 😀
