First post, by Hazekel
- Member
Getting Legacy-Dark Shadows running on Windows 7 (64 bit) was hard enough to start with, but I finally got it installed and starting with major bugs. The biggest bug is, as you can see by the attached JPG, the menu does not work properly. I can move my mouse around and find the appropriate place to click for "NEW", "SAVE," "LOAD," etc but when I attempt to SAVE or LOAD the save and load screens pop up on the left side of the screen and have small buttons which I cannot click (nor can I find the appropriate place to click). This makes the game unplayable.
I suspect that this could be a bug with changing the screen size and resolution from the original, but I have tried every trick I know including setting resolution from desktop and it still loads the exact same.
Has anyone else run into this problem and is there a patch or fix for it?
Thanks in advance;
David
