First post, by Hamby
I have been struggling for months (off and on) to get my K62-300 system to run Windows 98SE, using a Startech ICD2CF adapter.
Usually I get partway through an install from CD, and it crashes hard.
I was using an 8GB Transcend industrial CF... the other day I got bad sector errors on it.
I switched it for a 32gb Sandisk ultra. I burned, with great difficulty, an image of Win98SE onto it.
It seemed to work, but needed some drivers... except my CDROM was not being found in the bios.
I could have it cable select or slave, on it's own separate ide cable on the secondary IDE channel... no dice.
I noticed just recently (which means it could have been happening for some time), that on the startech, sometimes the red light would be on at boot... sometimes both red and green lights would be on.
I further noticed that sometimes neither light was on, and of course the computer couldn't find the drive.
After some experimentation, I discovered that the power adapter for the IDE2CF was loose; if I move it, the lights would pop on and off.
Before discovering this, I tried firing up the computer with just the CDROM... it found it just fine.
I tried firing up the computer with both connected to power (the system has a 400watt AT switching power supply), but with the ide2cf disconnected from IDE, it couldn't find the CDROM.
I tried with both connected to the ide cable, and the startech not connected to power... it found the cdrom.
I've tried connecting different power cables to each... no improvement.
I'm at a loss as to what could be happening?
Has anybody else encountered a problem like this?
Reply 1 of 3, by Warlord
do u have both on the same cable?
Reply 2 of 3, by Hamby
Warlord wrote on 2020-08-16, 08:32:
I did.
Then I tried putting the CDROM on a separate cable on the secondary IDE... I put it at the end of the cable. Tried it both CS and slave... no luck
After a few hours trying everything I could think of, going over the jumpers on the ide2cf, reseating the cf card, I decided to leave the CDROM set to "slave" and on the middle connector of its ide cable, and connect the ide2CF on the end of the ide cable connected to the secondary IDE channel....
and it worked. There were a couple times it couldn't find the CD as I updated Win98SE, but I suspect that was driver issue, because the bios was still finding both.
No idea why it worked; no idea why the other didn't work.
So now it appears I have a working K6-2 300mhz, 256mb ram, Nvidia GeForce2 MX200, C-Media SB-16 compatible, network-connected Win98SE system.
One curious thing; I discovered that the motherboard has USB support in the bios. I turned it off when my video card gave me a i/o conflict (turns out I was somehow trying to load two MX200 video card drivers). I'm going to turn it back on and see if my problems come back.
Reply 3 of 3, by Warlord
you might have bad cables, and then u out of luck found the cable that wasn't bad and just hooked them both up to the good cable.
