First post, by jasa1063
I picked up an old AT desktop case and the Turbo Button cover is missing. Anyone know if there is any place a replacement could be found?
https://1drv.ms/u/s!Ar6NijzQIpZIjH2Jjjx9h2ciSZYL?e=r9P0T1
Thanks!
Reply 1 of 3, by Warlord
id take the reset button off and try to get that 3d scanned and printed. then modify the 3d print so it can work somehow.
Reply 2 of 3, by Doornkaat
I think that's called a (push) button cap. There's a vast selection. Try if the reset button cap fits the turbo switch. If it does measure the cap and click through hundreds of offers until you found the closest approximation. 👍
Reply 3 of 3, by jasa1063
I finally ended up buying a AT front face plate and other accessories for only $23. Most of which I can reuse in other projects. I took the Turbo button off of the face plate and put it on my Aopen case. It matches perfectly!
