First post, by lillilor
Hello guys,
i'm using dos box version 0.74-3, i've got an issue when try to run dos box full screen.
image isn't resize to full wide screen surface, see attached file.
my .config file:
fullscreen=true
fulldouble=true
fullresolution=original
windowresolution=original
output=overlay
autolock=true
any hint?
    4.67 KiB
Reply 2 of 2, by digistorm
fullresolution =original can also ruin the party, when your graphics card or monitor don’t support the original resolution. Better to set the fullresolution to your panel resolution in that case.
