Help identify Bios chip
First post, by TimWolf
Want to back this 40pin chip up. Cant find it on my eeprom reader list. I am a novice at this. Using a USB Top835 to back up my older computers bios.
Thanks for any info in advance.
TW
Reply 1 of 7, by debs3759
To identify it if your reader can't autodetect it, you will need to remove the sticker. There is software that can read and save it in situ, but I have never done that, so will let someone else advise on that.
Reply 2 of 7, by quicknick
This looks to be the keyboard BIOS/controller. If I'm right, its contents cannot be read with simple means (including most of the cheap USB programmers).
Reply 3 of 7, by TimWolf
debs3759 wrote on 2020-08-21, 23:42:
Nothing under the sticker.
Reply 4 of 7, by TimWolf
quicknick wrote on 2020-08-22, 00:52:
How would you replace it? I want to make sure that I have future security in case of a malfunction.
Reply 5 of 7, by luckybob
short answer: you take one from another motherboard.
This is why i typically throw NOTHING away.
Reply 6 of 7, by Horun
TimWolf wrote on 2020-08-22, 03:50:
luckybob wrote on 2020-08-22, 04:44:
Agree ! It is a KB controller. It is a 8042 controller variant. Best way to replace it is get another KB controller chip. It generally has control logic, small scratch ram and 1k to 2k of pre-programmed ROM plus some peripheral interface logic. There is no way to directly read and save the rom part and would do no good since you cannot flash another KB controller with same rom contents. Any KB controller from same era motherboard should work just fine.
Reply 7 of 7, by TimWolf
Thank you all very much.
