First post, by chublord
Is there any trick to getting Ontrack to work with multiple large disks? It works fine on a single 4 GB Fireball or a single 250 GB WD Caviar, but I can't get it to detect both the Fireball and Caviar at the same time.
I've tried them on different ATA channels, master/slave, etc.
IBM Valuepoint 486 DX4-100, Opti 802G, 50 MHz FSB, Voodoo1+S3 864, Quantum LPS 540 MB + Seagate Medalist 1.6 GB + 4.0 GB Quantum Fireball, 128 MB FPM, 256k L2
Reply 1 of 1, by chublord
Found out that the 4 GB Quantum is actually supported in the BIOS without Ontrack at all, even though it doesn't show up correctly in the BIOS (shows as a 10 MB hard drive but appears fine from a boot disk). Tentatively I think it's working in this configuration:
540 MB Quantum (primary master)
4 GB Fireball (primary slave)
250 GB Caviar (secondary master)
CD ROM (secondary slave)
I had to go into Ontrack and update the MBR for it to detect.
