First post, by InbetweenDays
Hi all,
I've got this card which appears to support four floppy drives... I'm trying to find info on the switch & jumper settings but can't identify it. I've been through all the 16 bit ISA controllers on stason and haven't found a match.
Anyone able to help?
494.9 KiB
Thanks 😀
It don't mean a thing if it ain't got 5-pin DIN.
Roland addict and founding member of the Association Of Molex Haters
Reply 2 of 6, by Horun
It has a ACC Micro 3201 FD controller chip with 8 DIP switch just like this one: https://www.vogonswiki.com/index.php/ACC_Micr … ctronics_KT-204. Your card does not have a BIOS chip so if the motherboard BIOS does not support 4 floppies then it will only work with 2 floppies (unless you load a device driver).
The jumpers are diff story and could not find anything similar in TH99
Reply 4 of 6, by InbetweenDays
Horun wrote on 2020-08-23, 16:02:
Thanks. I wasn't sure if the card has a BIOS or not so I guess that answers that question 😀
I've got another four floppy controller card that does work easily enough, but I was just curious after discovering this one too.
Reply 5 of 6, by Horun
No problem, wished we could have found a manual. The floppy part switch should match up with that link I posted.. hopefully. You could always play around with J1 thru J4 and use DOS MSD to see if/how it changes the Com and LPT ports. J5 and J6 are the two that will either be easy or hard to figure out.
