melbar wrote on 2020-08-26, 03:18:
Does every P200 MMX run at 233 MHz?
If it's the case, this would mean also that every P200 MMX has a unlocked multi...?
Locked multipliers were not a thing at the times of the Pentium MMX. The introduction of locked multipliers happened in response to the rise of counterfeit Pentium 2, Pentium III and early Athlon Slot A CPUs.
I am quite confident that every Pentium MMX supports four different multipliers. All Pentium MMX CPUs support x2, x2.5 and x3 (133, 166, 200 at FSB66). Dornkaat might very well be right that there are early P55C dies that Interpret the fourth setting as x1,5 (100) just as the P54C does, not as x3,5 (233).
