First post, by gex85
I have this FX 5900 XT graphics card that I received in one of those "scrap lots". It does not work at all and first I thought it was due to the bulged caps and ordered some replacements for recapping it.
Upon closer inspection I saw that a transistor (?) on the back side of the card was knocked off (but still there). The silkscreen identifies it as Q502. It can't be soldered back in place because the legs are ripped off, so I need to replace it.
Unfortunately I can't really identify it. The inscription is really tiny but readable, see pictures below. I tried googling different variants:
- GOA3T
- G0A3T
- GDA3T
- GOA8T
- G0A8T
- GDA8T
But none of these returned plausible results. The package seems to be SOT-23.
8.18 KiB
Transistor
101.76 KiB
Transistor
653 KiB
Card
There is a second identical component (Q501) that I could try do de-solder and then measure, but since I do not have special SMD soldering equipment nor extraordinary soldering skills, I'd rather avoid that.
Any help would be appreciated.
EDIT:
After some more googling I might have found two possible candidates:
1. IRLML2502 (fast-switching MOSFET, would make sense) --> Datasheet: https://www.infineon.com/dgdl/irlml2502pbf.pd … 1535668048e2606
The code would translate to:
G = Part No. IRLML2502
0 = Year 2000
A = Week 01
3T = Lot Code
2. HSMP-3890 (single diode, which would not make much sense imo) --> Datasheet: https://media.digikey.com/pdf/Data%20Sheets/A … P-389x-489x.pdf
My retro computers
Reply 1 of 5, by kalohimal
I think you've found the correct one, IRLML2502, which is an n-channel mosfet. It's part of the buck converter, and the circuit right out from the datasheet of the pwm ic ISL6522 is like this:
45.96 KiB
Slow down your CPU with CPUSPD for DOS retro gaming.
Reply 3 of 5, by gex85
Today I found some time to solder on the replacement transistor. Power on - success!
110.66 KiB
POST
Some time ago I received this Revoltec VGA cooler as part of a bigger lot. Didn't think I'd even use it one day, but since the stock cooler was missing the aluminium top plate, I decided to give it a shot:
169.55 KiB
Revoltec
So this is the end result:
490.42 KiB
Result
Completely recapped with Panasonic caps, too. I haven't tested it beyond the BIOS POST yet, but I'm pretty confident that it will be fully working again 😄
My retro computers
