First post, by Vaudane
Dismantling my Asus CUSL2-C board to check it's all ship-shape before I fire it up for the first time, I take the cooler for the north bridge off to check the thermal paste and... what thermal paste?
There was none. It was just an ali heatsink plopped on top, held down with two sprung plastic rivets. No wonder people complained they ran hot back in the day.
Is this common on old boards?
As an aside, will be measuring it up for a wee active cooler in due course. If anyone knows any good ones for this board, let me know please!
Reply 1 of 9, by paradigital
I’d rather be greeted with no TIM than a heatsink that has clearly been epoxied on in one or two corners and you can see is nowhere near flat (I’m looking at you STB with your 3DFX Voodoo 3 garbage!).
Reply 2 of 9, by Vaudane
paradigital wrote on 2020-08-27, 16:34:
Touché. That wasn't even just restricted to the voodoo 3 either. I've read a few horror stories about similar on the voodoo5. *shudder*
Reply 3 of 9, by Doornkaat
Yes, this is common. Thermal paste isn't crucial with this low TDP but it certainly won't hurt to apply some now. 😉👍
Reply 4 of 9, by Vaudane
Doornkaat wrote on 2020-08-27, 17:54:
I've actually tried to find the TDP figures for the northbridge without success. I know the CPU itself is <35W so I'm not expecting stupid numbers though. Trying to work out if a fan would be massively overkill although as I said, I've read about people complaining they run hot. There is a nice wee 2-pin fan header right beside it I've been eyeing up for it which would be perfect for a 40mm fan...
Reply 5 of 9, by chrismeyer6
With these parts getting older you can never have too much cooling. I always try to make sure I have the best airflow and cooling I can
Reply 6 of 9, by cyclone3d
chrismeyer6 wrote on 2020-08-27, 18:34:
This right here. Even when this stuff was new I always made sure everything had more than adequate cooling.
You could even buy aftermarket north-bridge coolers back then. The best was one that had a heatpipe or two.... asked my little brother to save that one for me but he tossed it... grrrrrrr.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 7 of 9, by dionb
cyclone3d wrote on 2020-08-27, 19:28:
In the P3 era? Can't recall any kind of aftermarket heatsinks for northbridges being a thing then - in fact quite a few OEMs ran i440BX, i810 and i815 without any heatsink at all. First aftermarket heatsink I can remember was a blue passive Zalman affair designed as a silent replacement for active HSF combos on late 00's.
That heatpipe thing sounds impressive regardless. Any brand/model info?
Reply 8 of 9, by Doornkaat
There's that Alpenföhn Ötzi chipset cooler that uses two heatpipes and is all copper. I bought one NOS two or three years ago because it's kind of funny and only cost 5€.
Also some Thermaltake thing with heatpipe and blue LED 40mm fan comes to mind.
There's a bunch of others too. I think Cooler Master made one, Noctua probably, Thermalright, Evercool, probably a lot more I'm forgetting or not aware of and I think there are still new Chinese products around. Swiftech also made one (without heatpipes) in that hedgehog design - a very capable cooler IIRC.
I remember aftermarket chipset/gpu heatsinks as a commercial product starting in the early 2000s.
Reply 9 of 9, by cyclone3d
dionb wrote on 2020-08-27, 21:01:
I think the one we had was for a later platform.... Probably Pentium IV or Core2 era. Might have been used on an nforce 4 board or something like that that had a hot running NB.
I looked and there are some available on ebay. Just do a search for chipset cooler heatpipe.
The other bad thing about the stock chipset coolers back then besides the ones that came with no TIM were ones that had that pink bubble-gum like crap that was supposed to be TIM.
YMF7x4 Guide
