First post, by adalbert
I would like to solder an OpenWRT wifi module to 3C509B ISA card https://www.vogonswiki.com/index.php/3Com_3c509
so the machine would be able to connect to wifi through internal network card and packet driver. But I would like to retain the ability to connect external network cable (not simultaneously).
I understand that 10baseT can work with only 4 wires.
I thought about soldering 4 wires to internal wifi module and leaving 4 other wires for external device. I would also disconnect 4 pins used by internal module from RJ45 connector on the card.
When external ethernet device would be connected, I would swich off the +5V power from the OpenWRT module.
Would this setup work? Do I have to disconnect 4 pins used by internal module from the RJ45 connector, or it would be sufficient just to turn off that module when I want to connect external cable?
Is there any damage possible when external cable is connected and both devices are turned on?
BTW I would desolder the DB15 connector and install the device in such a way that wifi antenna is next to that hole.
AT(X)Anything: a modular DC-DC PSU for old PCs (open hardware)
