First post, by Steapa
I'm having problems connecting my PC speaker. I found the manual of my motherboard, and it says I need to connect the speaker at "JFP location 6-10":
https://www.elhvb.com/webhq/models/486vlb3/ms4138.txt.html
My speaker connectors have two pins:
I tried to connect the pins here... (red square):
...But it didn't work. I'm doing this wrong? What does 6-10 mean?
Sorry if it's a dumb question, I never build a pc before.
Reply 1 of 3, by Horun
Pins 6 & 10, here is a scan of part of the manual. The attached .zip has more images.
Reply 2 of 3, by Steapa
Horun wrote on 2020-09-10, 19:29:
Thank you, it worked!
I connected it to pins 7 & 10 instead of 6 & 10, like the manual you posted was showing.
