Mapower PD-80 PSU issues
First post, by Errius
Hello guys. I'm trying to debug this external drive PSU. It's a Mapower PD-80 and just outputs the standard 12V/5V over a couple of Molex connectors.
However, this particular unit is putting out 9V instead of 12V. Is this a capacitor problem?
(The gunk on the capacitors is not electrolyte but glue from a couple of labels that I pulled off. The capacitors have not burst.)
"AI Requires Proof That You Are Human"
Reply 1 of 2, by quicknick
Secondary capacitors appear to be Fuhjyyu "brand", which is one of the worst. Responsible, among others, for the deaths of countless Antec PSU's in the mid-00s. Replace them, and also check the fat one although it looks to be made by Hitachi so it should be still good.
Reply 2 of 2, by Errius
Ok, thank you!
