First post, by Almoststew1990
I am trying to build a M-ATX Windows 98 PC but my current SIS chipset board gives me Windows Protection Errors as soon as I boot into Windows 98 after installing the chipset drivers.
What chipsets are most compatible with Windows 98 that I should keep an eye out for?
Reply 1 of 29, by Wolfus
I still have W98 rig with VIA KT400 based board (Abit KD7) which works great with drivers from supplied CD. Unfortunately it is not mATX...
Reply 2 of 29, by kolderman
Intel chipsets work best for s478 imo. i865 is nice for win98.
Reply 3 of 29, by The Serpent Rider
That depends on what do you want. Do you need AGP 1.0 compatible slot? Do you need ISA DMA support?
Reply 4 of 29, by Almoststew1990
Err I'd want it to work with PCI soundcards but wouldn't need ISA slots. No need for an AGP 1.0 slot all the cards I use support both AGP slots.
Reply 5 of 29, by Cobra42898
i have an d865gbf (geniune intel) that works great with win98se
Searching for Epson Actiontower 3000 486 PC.
Reply 6 of 29, by The Serpent Rider
Not ISA slots, ISA DMA through PCI.
Reply 7 of 29, by bloodem
Both socket A (especially later chipsets) and socket 478 with an Intel 865 chipset work great with Windows 98. Although I prefer socket A for its flexibility, but seems that you are not necessarily interested in that so... in your case socket 478 with a Pentium 4 Northwood could be better, especially because you can use modern power supplies without any worry, even for the most powerful CPUs.
2 x PLCC-68 / 4 x PGA132 / 5 x Skt 3 / 1 x Skt 4 / 9 x Skt 7 / 12 x SS7 / 1 x Skt 8 / 21 x Slot 1 / 8 x Slot A
Current PC: Ryzen 7 9800X3D
Backup: Ryzen 7 5800X3D
Reply 8 of 29, by Wolfus
You can use modern PSU on Socket A boards as well. They do have auxiliary 4-pin connector.
Reply 9 of 29, by SpectriaForce
Wolfus wrote on 2020-09-14, 12:36:
Not all of them, certainly not the earlier ones.
What for capacitors does the board have?
Reply 10 of 29, by imi
that really depends, if the board uses 12V for CPU power then yes, but a lot of socket A boards rely on 5V and for higher power systems modern PSUs just don't deliver enough on the 5V rail.
Reply 11 of 29, by Wolfus
Oh, than accept my apologies. I have 4 of them and the all have it 😮
Reply 12 of 29, by bloodem
Man, you are lucky! I've played with tens of Socket A boards and I've only seen one with the 12V CPU connector (I believe it was an ECS with nForce 2 Ultra chipset). Anyway, I think less than 1% of socket A boards have it and they are generally very hard to find. 😀
Also true is that I only have VIA socket A boards (for obvious reasons), and I don't think I ever saw a VIA socket A board with this connector.
Reply 13 of 29, by The Serpent Rider
Anyway, I think less than 1% of socket A boards have it and they are generally very hard to find. grinning face
Almost all nForce2 boards have it.
KT880 boards.
Reply 14 of 29, by bloodem
Maybe, but definitely not all KT880 boards... It just so happens that I have one right next to me.
Reply 15 of 29, by The Serpent Rider
That's ASUS. They were cheap enough to not include 12v on their premium nForce 2 board.
Reply 16 of 29, by Wolfus
In that case, I am very happy my first board from 2000's has been Abit KD7 😀
PSU killed CPU (Athlon XP 2000) in 2012 but board survived with just few bulged condensators. I should change them 😒
Reply 17 of 29, by bloodem
The Serpent Rider wrote on 2020-09-14, 13:50:
Yeah, I can believe that 😀 Anyway, they are rock solid boards (once you replace the caps) and they usually have tons of BIOS options. I also have two Asus A7V600-X boards (not only my favorite Socket A board, but it's a solid contender for my absolute favorite retro board).
Reply 18 of 29, by Almoststew1990
Thanks for your help everyone. The boards I've been looking at all have a 12v CPU power connector so I can use my modern power supply.
I actually got my 478 SIS 651 board to work in W98 by disabling the USB ports and removing the USB folder of drivers from the chipset driver. I also swapped in a 2.4GHz P4 instead of 2.8. I've just copied everything I need directly onto the CF card C: drive.
Regardless I think I'll still buy a socket A board just because I haven't really used them much. Is nForce 2 a good chipset for Windows 98? I've not had much luck with later basic nForce chipsets for Windows XP!
Reply 19 of 29, by bloodem
The very few nForce 2 Ultra boards that I tested with Windows 98 were fine - stable and fast (faster than VIA, but usually by ~10%, so nothing ultra-spectacular). However, without question, I would always choose VIA (hehe... never thought I'd ever say this 18 years ago 😀 )
Anyway, no matter which one you will choose, you can expect 200+ FPS in most scenarios even with slower Athlon XP CPUs. And you don't even need a fancy video card or anything: a cheap GeForce 4 MX 440 will be just fine.
