First post, by Dusko
- Member
Hello All,
I know what I'm asking here is not easy to answer, kind of need an expert but, here I go anyway. A couple of years ago I got a Roland SC-88 Pro (120v version), it was like new, manual, original box, everything was great, not a scratch. Played with it for a couple of months and it worked as expected. A few days ago I wanted to use it again and now the sound it's completely distorted, it's like a big crackly sound (I'm attaching a sample using the sound preview button: one short press, one long and another short at the end) .
So, I opened it up and noticed that in the main board, some of the Alum/Poly (smd) caps leaked, not a lot but they did. I replaced them (8) with spare ones I got from Digikey, nicely done, no traces lifted whatsoever and used the same values of course but, that didn't fix the problem. I got the Service Manual and compared the voltages from the transformer, there are 5 output pins as you can see in the picture. I did two tests, one with the transformer on it's own, (ribbon) cable disconnected from the Main board, and the second with the cable connected.
My readings with a Fluke multimeter: (AC)
with the cable disconnected from the main board:
on the 12v ones I get 16.77v each
the 5v gives me 6.22 and the other 2.17
with the cable connected to the main board:
on the 12v ones I get 16v each
the 5v are aprox. 3.98v each
Either way, theses numbers are all wrong, correct? am I missing something? I don't see any signs of heat damage or leakage (except the caps I mentioned from the Main board), everything looks good, no funny smells, etc. Does anyone that has this unit can check those voltages and let me know? If mine are all wrong, that probably damaged some chips right? I guess replacing the transformer would be too late...
More finds:
I tested some voltages that go to the main board and got these values: (DC) 4.9v, 3.6v, 2.48v, 0.9v, some numbers look really odd but I don't know.
In the "analog" or secondary board, the (Japanese) electrolytic caps look in great shape, no swollen or leakage. Also, I did a test with the line-in and the sound is correct, no problems there.
Midi inputs get the signal but, that's when audio gets bad, same if I press the Preview button.
Display and buttons have no problems at all.
I did some of the tests from the Service Manual and got several errors with the "Memory Test", I'm attaching a screenshot of what the manual says it's wrong and it matches exactly with what is reported on the screen. I looked at all those chips but I can't find broken traces or burned marks.
If anyone has this problem before drop me a line please, either you fixed or not.
Thanks for reading!
Retro PC games channel: https://www.youtube.com/@myOldPC-75
Electronics, mods and tools channel: https://www.youtube.com/@RetroRust-75
