First post, by skel2raw
Hi guys,
I have the Gigabyte GA-5AX Rev. 4.1. I am curious though what difference between this revision and the revision 5.2 is since I read everywhere that the 5.2 is the one to have. Can anyone tell me what the deal with Rev 5.2 is and whether it is worthing trying to get one?
Thx!
Reply 1 of 13, by Doornkaat
Main difference is the VCC3 jumpers on Rev. 5.2 that'll connect VCC 3.3V directly to the PSU. I believe that is in reaction to newer AGP cards destroying some Gigabyte mainboards with their power draw.
Also I think only Rev.5.2 has the infrared connector if you want that. 😉
You can run a wire on the back of the board from the ATX connector to the AGP slot if your revision doesn't have the jumper.
Reply 2 of 13, by skel2raw
Oh I see... do you know what kind of cards are affeccted by this? Regarding IR, whatever would one be using that? I never understood what it was good for except for sharing data with old Nokia mobile phones which had infrared.
Reply 3 of 13, by mt777
the main difference (valuable) is A1 vs B1 revision of bridge. Then UDMA66 ability (similiar situation is with GA-5AA rev3).
I have both revisions (5AA babyat) but never check udma speed difference.
Reply 4 of 13, by bloodem
skel2raw wrote on 2020-09-19, 12:14:
The GeForce 256 was known to wreak havoc during that time, however even a Voodoo 3 card has ~ 15W of power draw, and this can be an issue with some boards (not sure about the 5AX, though, I never tested it, although I don't think I've seen anyone complaining about this when it comes to this particular board, regardless of revision).
Generally speaking, when it comes to SS7, I think there are only two good options: A Voodoo 3, or a GeForce 2 MX. However, the GeForce can be unstable on many SS7 boards out of the box, so you might need to brace yourself for a few days/weeks of debugging - until you find the right combination of BIOS version / BIOS settings / driver versions ). A Voodoo 3 is generally preferred by many, because it can be quite stable on SS7 (since it's not using any AGP specific features). However, it needs 3 times the power of the GeForce 2 MX, which can be a problem with some boards. Also, it's a bit too expensive nowadays.
The Voodoo Banshee can be a cheaper option (although, IMO this one is more suitable for a Socket 7 Pentium MMX build).
2 x PLCC-68 / 4 x PGA132 / 5 x Skt 3 / 1 x Skt 4 / 9 x Skt 7 / 12 x SS7 / 1 x Skt 8 / 21 x Slot 1 / 8 x Slot A
Current PC: Ryzen 7 9800X3D
Backup: Ryzen 7 5800X3D
Reply 5 of 13, by Doornkaat
mt777 wrote on 2020-09-19, 12:17:
You're absolutely right!👍 I have to admit even though I have both revisions I never noticed that.
I would not assume the speed difference will be noticeable on that platform. Obviously haven't knowingly tested it though.😅
Reply 6 of 13, by Rocket202
Doornkaat wrote on 2020-09-18, 12:32:
Doornkaat wrote on 2019-10-30, 12:11:
I generally agree. The chip gets very hot though so I understand this might seem troubling at first.
What's the rest of the setup, Moer? (Including motherboard revision if known.) And what BIOS? Normally a single long beep isn't VGA related. Edit: Nonsense, with later Award BIOS a repeated long beep indicates video or memory problems.
Edit2: If the motherboard is in fact the GA-6BXC Rev 2.0 you need to short JP12 and JP13 so enough power is supplied to the Voodoo. Otherwise the AGP VRM will overheat. This is a known issue with Gigabyte boards. The jumpers are a workaround bypassing the VRM and supplying 3.3V directly from the PSU IIRC.
(this quote is from another thread)
Hello.
I have the same board 5ax 4.1 + voodoo 3 2000.
Are you totally sure that the 5ax 4.1 need that agp mod?, checking the ga-6bxc it has a jumper literally designed for the voodoo (didnt mention anywhing about the voltage in the manual, just said voodoo 3), in the 5ax 5.2 the manual says:
JP13: VCC Voltage Setting
Pin No. Function
1,2 Close VCC3=3.58
2,3 Close VCC3=3.3
I have read about the hungry voodoo, and motherboards that cant handle the voodoo, but is this one of those?
I ended here because i notice the voodoo's board too much hot for being in the desktop, i know people say this cards are hot, but even in the desktop without load?.
Found the 3.3v pin from the atx connector, no idea what is the next step but I don't want to do any mod if I'm not sure this board is affected by it, I didnt find any other information on this board that clarifies this.
Thanks.
Reply 7 of 13, by gmaverick2k
I've bagged myself a revision 1.4 according to the eBay listing images on the bios boot screen. It's yet to arrive in the post as part of a system. Can someone tell me what the difference is Vs the revisions listed here?
apologies, rev 1.3
Main: Z440/E5-1650 V4/3060Ti/64GB/iFi Zen DAC V1/Klipsch ProMedia 2.1 THX/Philips 43PUS8808/12
98/DOS: Shuttle SK41G/AthlonXP 2200+ 1.8GHz/V3 3000/SuperQuad Digital/MU90/SC-55/SC-88 Pro/LG StudioWorks 995E
XP: Thinkcentre Edge 72/i5-3570K/GTX 970/X-FiTi
Reply 8 of 13, by Horun
The rev 1.x FSB only goes to 83Mhz stable, the later rev's go to 100Mhz and beyond stable < probably wrong remembering something about clock limited on first rev's...
added: there were added CPU support in the v4 and v5 that made it one of the best SS7 for overclockers
if you want a quick comparison check this page and scroll down to GA-5Ax: https://www.dosdays.co.uk/topics/Manufacturers/gigabyte.php
edit here is the Ver 1.x manual and quick Guide: https://www.elhvb.com/mobokive/Archive/Gigaby … 2_jul2198_m.pdf
and https://www.elhvb.com/mobokive/Archive/Gigaby … 2_jul2198_q.pdf
they are same as at wayback machine listing: http://web.archive.org/web/19991128184944fw_/ … super7.htm#ali7
Reply 9 of 13, by gmaverick2k
Horun wrote on 2022-09-25, 02:31:
The rev 1.x FSB only goes to 83Mhz stable, the later rev's go to 100Mhz and beyond stable < probably wrong remembering something […]
Wow thanks. That's a lot of useful information. Appreciate it
Reply 10 of 13, by danieljm
Hi everyone. So, I'm a little unclear... am I risking my parts if I pair my GA-5AX 4.1 with a TNT2 Pro or is it just likely to throw errors?
Would this 3.3V wire mod mentioned earlier be the solution to all my problems? And anyone able to give any direction on how to do it? I am comfortable with basic soldering.
I ordered a TNT2 Pro before finding out about the potential problems and I just received it today, so now I'm antsy to try it. Someone please help this poor, ignorant fool. 😀
Reply 11 of 13, by gmaverick2k
Just received it. It has the model number and rev upside down. It reads rev 4.1
Reply 12 of 13, by Horun
gmaverick2k wrote on 2022-09-28, 21:25:
If it is a rev 4.1 That is a good thing 😁
Reply 13 of 13, by Doornkaat
Rocket202 wrote on 2022-08-18, 21:41:
(this quote is from another thread) […]
Hello.
Pin No. Function
1,2 Close VCC3=3.58
2,3 Close VCC3=3.3
Thanks.
Hi! I hadn't logged on in a while so my answer is a bit delayed, sorry.
I can't tell wether some GA-5AX revisions have Voodoo jumpers. Apparently revisions of affected Gigabyte boards without the jumpers are a bit hit or miss: Some will work without it, some won't.
The Vcc3 jumper has most likely nothing to do with this issue. It's about CPU core valtage.
The Voodoo3 itself getting hot is normal and has nothing to do with the regulator. It's a hot card - 2D vs. 3D does not make that much of a difference in this generation of video cards. Point a fan on it and see if it'll run stable.
I don't have the time currently to help you with figuring out the details of how to do the AGP power mod on this particular board. Sorry. 🙁 Maybe somebody else feels up to it?
