First post, by BEEN_Nath_58
Lately, I returned to play GTA 2 and found that it had the SafeDisc problem. I did the usual patching to latest version with a no CD but it did work out. So I had to take a modded patch which would work but won't use CD Audio. So the radios and music won't work. This won't happen with Windows 7 and the game works as soon as you put the no CD and the Audio plays.
Is there a way to get the SafeDisc DRM working again, through official or unofficial means?
Reply 2 of 2, by BEEN_Nath_58
1541 wrote on 2020-09-22, 19:54:
This approach seems to work
https://youtu.be/Hr3_OGD_AeQ
This approach is legit, but it didn't work. I tried setting compatibility to Win7 but the Login with admin privileges problem exist. I also used a newer version of the file from 2012.
