First post, by debs3759
Can anyone recommend a free and/or open source ISO file creator and burner? Got loads of CDs and DVDs I burned 20 to 25 years ago I want to copy (collections of programs I downloaded from BBS and web sites in the 90s that will be useful for vintage systems that I want to salvage before all the old disks degrade too much). Trying to get out of the habit of using pirated software as much as I can 😀 Not too concerned if I need to run software on an older version of Windows.
Reply 1 of 11, by leileilol
ImgBurn's not open source but satisfies a lot of the reading/making/burning needs, though I hear bad things about some later versions having crapware (I haven't updated in years) and its reading ability/ccd creation isn't as good as CloneDVD when it comes to those pesky Safedisc games and super old CDs (try both, because results may vary).
Tread the open source line and you'll run into CLI stuff like dd/ddrescue, mkisofs, etc. and some buggy programs like infrarecorder and brasero. I never had much luck with them personally 10 years ago.
Reply 2 of 11, by debs3759
Open source isn't a deal breaker, it's just a concept I like. I'll have a look at ImgBurn and see if it meets my needs. Thanks.
Reply 4 of 11, by debs3759
hmm. Downloaded ImgBurn and ZoneAlarm detected it as infected, and deleted it. CDBurnerXP looks OK, I'll try that. Thanks.
Reply 5 of 11, by debs3759
Installed CDBurnerXP, and it looks perfect for my needs. Will find out later, when I dig out my Win95 and NT app backups (if the discs are still viable).
Reply 7 of 11, by debs3759
I've been using Nero for many years, but that is the last pirated app to be replaced on my main PC. And CDBurnerXP uses so much less space on disc 😀
Reply 8 of 11, by Errius
I have always used Alcohol 120% for backing up CDs.
"AI Requires Proof That You Are Human"
Reply 9 of 11, by jmarsh
debs3759 wrote on 2020-09-23, 02:27:
If you get the installer from the official imgburn website it comes bundled with adware. But the installer on most mirrors (e.g. MajorGeeks) is adware free.
Reply 10 of 11, by Benedikt
I have used cdrdao (part of cdrtools) with great success, so far.
It is mostly used for iso files or bin/toc file pairs. The slightly more common bin/cue format is also supported to some extent.
Virtually all Linux distributions ship with cdrtools and there is a whole zoo of GUI front-ends. There should be windows versions, too.
Actually, IIRC, InfraRecorder is not much more than a cdrtools front-end.
Reply 11 of 11, by debs3759
jmarsh wrote on 2020-09-23, 05:08:
I downloaded it from MajorGeeks, they are usually a very good source. CDBurnerXP does what I need without being overly bloated.
